tub and shower inserts
Discussion in 'Shower & Bathtub Forum & Blog' started by Puds, Feb 21, 2005.
  1. Puds
    Puds New Member
    Feb 21, 2005
    Insurance,EMT,telecomm
    ohio
    Installing new tub with shower insert. Still undesided on using Steel or Fiberglass tubs sold with the inserts. I have read the responses about the leaks of steel tubs with the insers. Conclusion; properly installed (leveled) steel tub with shower insert (caulking) should not leak.
    If I choose the fiberglass tub, would you advise against me using foam insulation from the spray can for the reinforcement under the tub? I figured the expanding properties of that stuff (actual name of one brand) would make and ideal support under the tub forming to all it contours.
    Thanks puds
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    I like to use sand mix under the tub. You're going to want whatever is under the tub to be solid. You can push your thumb into expandable foam after its set up....not solid enough for me.
  4. Puds
    Puds New Member
    Feb 21, 2005
    ohio
    Thanks for that suggestion RioHyde. I am leaning toward the fiberglass tub or what ever there made of these days. Hopefully my wife won't drop the shampoo bottle and crack the tub.
    Thanks again.
    Puds
Similar Threads: shower inserts
Shower & Bathtub Forum & Blog Best finishing process for tub/shower inserts Aug 11, 2007
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Concrete shower pan; do I need a liner? Feb 14, 2017
