Tstat Common Wire
Discussion in 'HVAC Heating & Cooling' started by PTN, Nov 12, 2007.
  1. PTN
    PTN New Member
    Feb 6, 2007
    Norwalk, CT
    i want to install programmable thermostats. one each for the upstairs and downstairs zones in my 2000SF raised ranch.
    right now i have the basic honeywell round tstats.
    the one downstairs has two wires which are not labeled. the upstairs handles AC and heat and has the following wiring;
    separate wires to R and Rc with an additional jumper wire between the same two terminals. Also, W, Y and G.
    I have 2 Taco zone valves (3 terminals) and no C wire (constant)to either tstat. However, i would like to use the extra wire already installed at each tStat which is not connected to anything to bring constant voltage to be used for the new programmables.
    Could you tell me where i need to hook to at the boiler/transformer end to get the common voltage to power the new Tstats?
    i could get pics of the wires if needed...
    Thanks.
Similar Threads: Tstat Common
HVAC Heating & Cooling Replacing Carrier TSTATCCPRH01-B With Ecobee Smart Wiring Question Jan 22, 2014
HVAC Heating & Cooling Replace White-Rodgers IF92 Tstat with new Honeywell VisionPro Jun 23, 2010
HVAC Heating & Cooling changing heat only tstat to heat and cool tstat May 3, 2010
HVAC Heating & Cooling I absolutely need to use a common wire to install my Nest...which is the common? Dec 7, 2016
HVAC Heating & Cooling Wiring diagram for furnace relay & thermostat common wire May 26, 2016
