njfiddler
I need to replace an adapter that is screwed onto the end of the supply pipe, onto which my old spout fits with a friction fit. I can see a couple threads, so if I remove the adapter, I will have 3/4" male threaded pipe to mount a standard spout onto (I can't find spouts to match the old one).
From the wall, it's 1/2" copper, then a unit is soldered on: a short sleeve, then a hex nut, then the 3/4" threaded part.
Here's my problem: the adapter won't come off. Part of the problem is the adapter is round, thus difficult to grip. The other part is it seems to have bonded to the threads. I've tried WD-40 soaking. There is a greenish chalky substance on the exposed threads; is there a certain solvent I should use?
