We're on well water and have been putting up with some issues for a few years -- e.g. green/blue stains in the tubs and showers, murky tan colored water sometimes (especially after the main water has been shut off and turned back on). I finally got 3 plumbing/water treatment companies to come give estimates on solutions but they each diagnosed different degrees of problems and recommended something different. Would appreciate some opinions on what's best.
Company #1
1) I realize we definitely need an acid neutralizer. Which size and brand is best? We have 6 people in our household if that helps.
2) Do we also need a softener and/or iron filtration system?
3) For the acid neutralizer, one company said in addition to annual refills the tank would have to be replaced every 3-5 years due to buildup while the other companies only mentioned the annual refills. Is the tank swap out really necessary?
Company #1
- Diagnosis: pH 6.5, hardness: 2, iron: 1
- Recommendation: 2.5 cubic ft. downflow acid neutralizer (Impressions) plus 48,000 grain softener
- Diagnosis: pH 6.0, hardness: 2, iron: 0
- Recommendation: 1.5 cubic ft. downflow acid neutralizer (Entek)
- Diagnosis: pH 6.25, hardness: 5, iron: "a lot"
- Recommendation: 2.5 cubic ft. downflow acid neutralizer (Hydrotech) and softener and iron filtration system
- pH 6.7, iron 0.2 mg/L, copper 1.55 mg/L, hardness 33 mg/L or 1.9 gpg, Corrosivity Index (Ryznar) 11.6, Total dissolved solids 78 mg/L
