Trying to Avoid A Major Disaster..Advice Needed
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cemian, Apr 23, 2013.
  1. cemian
    cemian New Member
    Apr 23, 2013
    Florida
    Hi everyone
    I was wondering if this could be a DIY job or does this need the services of a licensed plumber to solve? The inlet pipe going into the water heater has rust on it as you can see in the picture...can this be cleaned off and fixed or does the this pipe need to be replaced? Doing so will need the entire water supply of the condo building to be shut off affecting everybody in this building..so if I could find a solution to avoid this would be all the better...looking forward to your comments..thank you
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It needs to be replaced. You should get a plumber to do it.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Most condo associations require that plumbing, electrical, and other building repairs be done by licensed professionals and condo owner are not to mess with these things. You should not DIY even if the condo association permits it because of potential liability issues should there be a mishap during or after the repairs. My advise is don't touch it. Check with the association on what their rules are and follow them. It does look like the valve should be replaced, but there may be more problems that you can't see. It doesn't appear that there is an immediate danger, so you have some time to work with.
  5. hj
    It should be replaced, but there is not enough room to "just" replace it. Some of the other piping will have to be revised to make room for the replacement. Probably NOT a DIY job.
  6. cemian
    cemian New Member
    Apr 23, 2013
    Florida
    Thank you for your responses...will have a licensed plumber take care of it then :)
Similar Threads: Trying Avoid
Plumbing Forum, Professional & DIY Advice Moen Monticello. Trying to Remove Bathroom Faucet Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Trying to remove the Faceplate on a Kohler Shower Faucet. Tried Everything. Help! Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Trying to surface cleanout above finished floor May 16, 2016
Plumbing Forum, Professional & DIY Advice Trying to figure out overflow issue May 6, 2016
Plumbing Forum, Professional & DIY Advice Trying to locate a sink part Oct 8, 2015
