Thus far in my limited soldering experience I have only had one leaky joint. And it was a major screw up on my part. I had soldered a 3/4 tee on the hot water line leaving the Water heater. 1st dumb thing was I forgot to open the outdoor spigots so water would stop draining , and then the vaccum in the pipe would let loose a little and more water would come. I did the bread trick without realizeing I need to open the outside valves. Furthermore I had been in a hurry and forgot to clean the fitting.
Anyways I soldered the rest of it and put water too it and no leak. until 20 min later I notice a drop on the floor. Anyways if was slow, like a drop every two minutes, I decided to ignore it as it was dripping on an unfinished basement floor. Eventually it stopped. And it stayed stopped for about 2-3 weeks. Then it started again.. about a drop every 5-10 seconds. So I made plans to fix it on the weekend.
Anyways I get home at 9 pm from work the next night and I've got water spraying out of the joint on the top and a pencil stream out the bottom. Luckly I had all the stuff for a repair and by 12 I had fixed my leaks. This time I opened ALL faucets and water drained out fast and I was able to work with a completely dry joint...no bread necessary.
