Troubleshooting two 3-way switch setups
Discussion in 'Electrical Forum discussion & Blog' started by Thatguy, May 7, 2009.
  1. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    or can I have wires crossed
  2. firecap04@gmail.com
    firecap04@gmail.com New Member
    Jan 16, 2012
    Toledo
    That's helpful. Thanks
  3. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    how about this
  4. firecap04@gmail.com
    Jan 16, 2012
    Toledo
    That explains it for me. Thank you
  5. MeasureTwiceCutOnce
    MeasureTwiceCutOnce New Member
    Feb 1, 2012
    Florida
    (IGNORE THIS POST: Problem apparently gone) This one seems a mystery. Went to one of my empty rental properties where I was unaware of any previous problem, and noticed some lights not working. Tenant had turned one breaker off. I turned it on and that breaker controlled two 3 way switches in different rooms that control parallel lights on back patio. There's also a pigtail on what may be the feed (didn't test yet) which likely goes to a single pole in the same room as one of the two 3-ways (or perhaps a receptacle also). Problem is, with breaker on, patio lights stay on all the time no matter what combination is made with the switches (i.e., on, on, on, on). Had to turn breaker back off and haven't gone back to diagnose yet (travelers SEEM to be wired OK at quick glance), but is there an obvious solution here??? UPDATE: For no apparent reason, everything is now working properly. Tenant must have come back to do something, but it wasn't obvious. Anybody ever seeing an on/on/on/on condition is still welcome to reply.
  6. Amy Broderick
    Amy Broderick New Member
    Jul 15, 2012
    Utah
    Off
    On
    On
    On
    Please help!
  7. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    You have a common and a traveller miswired somewhere in the circuit. Do you know where the power comes to the circuit first? At the light or one of the switches?
  8. Amy Broderick
    Jul 15, 2012
    Utah
    Thanks for the reply ActionDave! The power comes to switch #1 first.
  9. jal
    jal New Member
    Aug 11, 2012
    New York
    Here is mine
    off
    off
    off
    on
    Switch 1 regular 3-way has the incoming hot wire - tested with a NCV detector
    Switch 2 is a dimmer with 3-way
    Tested the travelers with an ohm-meter - they are good
    Before this replacement
    Switch 2 was a dimmer where it only had two screws and a traveler and the common were connected to the same screw
    Switch 1 was a regular 3-way
    and the behavior was
    off
    on
    on
    on
    what is going on?
    thanks
    JAL
  10. jal
    jal New Member
    Aug 11, 2012
    New York
    Continuing with the above : I put the old 3 way switch and a new 3 way switch (no dimmer)
    I get
    off
    on
    on
    on
    just more info any help appreciated
    JAL
  11. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Anything other than this and the switch will not work
Similar Threads: Troubleshooting 3-way
Electrical Forum discussion & Blog Advice for troubleshooting a bad circuit Oct 11, 2009
Electrical Forum discussion & Blog GFCI Troubleshooting Help Needed Apr 23, 2009
Electrical Forum discussion & Blog Troubleshooting Ceiling Fan Jul 7, 2007
Electrical Forum discussion & Blog a single 3-way switch controlling a light fixture on a knob & tube circuit - why? Jun 12, 2014
Electrical Forum discussion & Blog 3-way switches with dimmers for lighting? May 2, 2014
