Troubleshooting two 3-way switch setups
Discussion in 'Electrical Forum discussion & Blog' started by Thatguy, May 7, 2009.
  1. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    This assumes two travelers between the switches.
    Assign each switch a number.
    With switch #1 & switch #2 down, light is on or off?
    With #1 up & #2 down, light is on or off?
    With #1 down and #2 up, light is on or off?
    With #1 & #2 up, light is on or off?
    In principle, with the answers filled in, the problem(s) can be pinpointed.
    Test cases welcome. . .
  2. sakkyoku
    sakkyoku New Member
    May 21, 2009
    off
    off
    on
    off
    Looks like I'm the first test case. How do I fix it?
    Thank you in advance.
  4. hj
    switch
    It appears that one of the travelers is connected to the common on one of the switches, therefore there is only one configuration where both are "on" to let the lamp operate.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Sw#1 is working like an on/off switch when #2 is up. When sw 2 is down there is no continuity.
    Either a traveler is not connected or it's like HJ said.
    Set both switches down so the controlled lamp is off.
    Assuming two travelers, like in most of the diagrams in this link
    http://en.wikipedia.org/wiki/Switch
    if you run a wire from the common of one switch through a 100w incand. bulb to the common of the other, the test light and the controlled (incand.) light should go on, equally faintly if they are both the same wattage. You can then safely put a piece of wire in place of the test bulb and you should get full brightness on the controlled light.
    If not, the wires feeding the common switch terminals are incorrect.
    You'll need an extension cord and clip leads.
    Never and I mean Never try anything that comes close to this. This is very dangerous and should never be attempted
    Thatguy this will be deleted should you ever post anything like this again. If you disagree PM me and we will discuss the safety issues involved.
  6. sakkyoku
    sakkyoku New Member
    May 21, 2009
    thanks
    I had switched a traveler and the common on both switches.
  7. golong27
    golong27 New Member
    Jun 17, 2009
    next case...
    off
    off
    off
    on
    I'm replacing the old dirty switches with new white ones and have two different 3-ways with the same behavior.
    switch #1 is the end of the circuit and #2 is in the middle.
    thanks in advance.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Check the switches using an ohmmeter as to operation and terminal labelling.
    Check that the common switch terminals go to the right wires and not one of the travelers.
    There is a slight chance that hooking up the switches incorrectly will damage a good switch so I'd run the light bulb test, but it is a bit inconvenient.
    NEVER use a light bulb tester for checking voltages
  9. Donwe
    Donwe New Member
    Nov 5, 2009
    Bend, Oregon
    Ok, here's mine.
    off
    on
    off
    off
    Thank you for your time.
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Assuming you have wired the switch common terminals [different color than the other two] and traveler terminals [same color] correctly, one of your travelers is open or one switch is internally defective in that there is no continuity between the common terminal and the traveler terminal when the switch is thrown to that position.
    It's an SPDT switch.
    http://upload.wikimedia.org/wikipedia/commons/thumb/b/b6/SPDT-Switch.svg/325px-SPDT-Switch.svg.png
  11. Donwe
    Donwe New Member
    Nov 5, 2009
    Bend, Oregon
    Thank you that was very helpful.
  12. hj
    wires
    We do not know what the wire colors are in your circuits, but the hot and "hot" to the light go on the bright brass terminals. The travelers, which might both be the same color, but should be the only two left when the proper wires are on the common, attach to the two dark colored terminals. They can be connected to either one.
  13. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    The travelers may have phantom voltages on them, so use a 120v incandescent bulb to check for voltages. Most testers will respond to phantom voltages.
  14. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    Normally the traveller screws are brass colored. The common is typically the dark colored screw.
  15. Donwe
    Donwe New Member
    Nov 5, 2009
    Bend, Oregon
    OK, so it was a bad switch, thank you again:)
    Here's a better one, I have three switches controlling an overhead kitchen light, switch one is a three way and is where the circuit starts and I have confirmed the hot leg is connected to the common post, switch two is a four way, and switch three is a three way. the problem is switches one and two will only control the light if switch three is on, any ideas?
  16. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Post what you believe to be the schematic.
  17. Donwe
    Donwe New Member
    Nov 5, 2009
    Bend, Oregon
    --- s === s === s --- o
  18. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Your schematic leaves something to be desired, but I think a traveler for sw 3 is missing
    or the 4-way is wired incorrectly or is bad.
    BTW, 'on' is not defined for 3-ways and 4-ways; that's why they are not labelled like other switches.
  19. hj
    wires
    All it takes is for the common and a traveler to be interchanged and the circuitry will not operate properly. Mixing "line 1/A and 2/B" on the four way can also cause weird operation.
  20. Donwe
    Donwe New Member
    Nov 5, 2009
    Bend, Oregon
    Thats what it was, once I isolated the traveler pairs and re-connected everything works just fine, Thank you!
  21. alth
    alth New Member
    Dec 21, 2009
    Canada
    Trouble with 3way Switch!
    Hi there hope you can help:
    Will a 3 way switch with the following configuration work for my stairs to basement, and if it will how can I fix it:
    Live Feed
    l
    l
    Switch #1 ---- Switch #2------ Light # 2
    l
    l
    l
    Light #1
    When Switch #1 is on and Switch #2 is off Light #1 works but Light #2 does not
    When Switch #1 is on and Switch #2 is switched Light #1 turns off and Light #2 turns on
    When Switch #1 is off and Switch #2 is switched nothing happens
    Thanks for the help!
Similar Threads: Troubleshooting 3-way
Electrical Forum discussion & Blog Advice for troubleshooting a bad circuit Oct 11, 2009
Electrical Forum discussion & Blog GFCI Troubleshooting Help Needed Apr 23, 2009
Electrical Forum discussion & Blog Troubleshooting Ceiling Fan Jul 7, 2007
Electrical Forum discussion & Blog a single 3-way switch controlling a light fixture on a knob & tube circuit - why? Jun 12, 2014
Electrical Forum discussion & Blog 3-way switches with dimmers for lighting? May 2, 2014
