Trouble with pressure balancing valve
Discussion in 'Shower & Bathtub Forum & Blog' started by jasdyer, May 4, 2008.
  1. jasdyer
    jasdyer New Member
    May 4, 2008
    Just bought a house that had been "winterized" for about 8 months. After de-winterizing all was well EXCEPT I get ZERO hot water flow from one of the Delta pressure-balancing tub/shower valves. It's about 15 or so years old. Any advice on where to star looking for the problem??
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Your balancing spool may be stuck. It shood be located behind the face plate of the faucet. It looks like a 1" diameter slotted screw.
  4. jasdyer
    jasdyer New Member
    May 4, 2008
    Thanks Crow
    Let's say I find it and assume that it's stuck. Now what? Hammer, screwdriver, wd-40? How do I unstick it?
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    1)You can try tapping on the large screw (Sometimes it will unstick).
    2)You can shut off your water and try to unscrew that large screw. Once its out
    ------a) Try tapping the entire spool on something hard and see if it loosens
    ------- b ) purchase an identical balancing spool and replace it
    ---------------- i) maybe HD
    -------------- ii) plumbing supply house
    ---------------iii) call delta for replacement part
  6. jasdyer
    jasdyer New Member
    May 4, 2008
    Thanks, again, Krow!
    Will do! I was kidding about the hammer! Guess I might use it after all. I appreciate the tips.
Similar Threads: Trouble pressure
Shower & Bathtub Forum & Blog Shower plumbing troubles Dec 23, 2014
Shower & Bathtub Forum & Blog Trouble with old Sayco tub faucet Oct 6, 2014
Shower & Bathtub Forum & Blog Trouble with caulk after remodel. Jul 24, 2014
Shower & Bathtub Forum & Blog Sterling Accord Install Trouble Apr 16, 2014
Shower & Bathtub Forum & Blog Kohler Mixer Valve replacement trouble(s) Apr 16, 2013
