Trouble with p-trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gregnoob, Nov 5, 2009.
  1. gregnoob
    gregnoob New Member
    Aug 6, 2009
    Virginia
    I am installing a new pedestal sink in my bathroom but ran into a problem with the p-trap assembly...
    I bought one of those kinds that has the 90 degree down turn that gets glued into the stub-out and then connects to the curved part of the trap by a big screw so that you can turn the orientation of the trap and then tighten. On the other end I glued a 1 1/2 to 1 1/4 adapter...
    When I poured water through the assembly, it leaked at the big screw part (see picture).
    I noticed that there in no plastic "nut" in the joint part where the leak is... Is there supposed to be? Am I supposed to do something to the joint to keep it from leaking? Am I better off just buying parts that can be simply glued together rather than mess with this "adjustable" stuff?
    [​IMG]
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    If that is a slip on piece then yes there should be the plastic piece. If that is a screw on part (both ends) then no.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Your pic is Sch. 40 PVC...I personaly would have opted for the 1 1/4" tubing trap...it makes this job less difficult... You should have a 1 1/4" Desanco at the wall and a tube trap and trap arm for the rest of the job...
  5. gregnoob
    gregnoob New Member
    Aug 6, 2009
    Virginia
    Thanks... turns out that the threading looks bad (gouged) on the male end of the connection and that's where I am getting the leak. I've got to cut the assembly off and I'll probably go with the 1 1/4 Desanco on the stub out and then use the 1 1/4 tubular trap as suggested.
    Think this is the only option to get things to line up now anyway seeing I have to cut and lose length.
    Thanks all!
  6. hj
    trap
    The "threading" does nothing except hold the parts together. You just need a better wrench to tighten it.
Similar Threads: Trouble p-trap
Plumbing Forum, Professional & DIY Advice Having Trouble Venting Bathroom Renovation Oct 26, 2016
Plumbing Forum, Professional & DIY Advice Trouble shooting submersible pump issue-20 year old pump Aug 22, 2016
Plumbing Forum, Professional & DIY Advice low water pressure troubleshooting May 25, 2016
Plumbing Forum, Professional & DIY Advice Help troubleshooting hot water running out quickly (replaced dip tube already). Nov 26, 2015
Plumbing Forum, Professional & DIY Advice Old 2 handle tub faucet trouble. Jul 30, 2015
