trouble removing old faucet - no room for basin wrench
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by grundy, Jul 26, 2008.
  1. grundy
    grundy New Member
    Jul 26, 2008
    hello,
    I'm trying to remove an old bathroom faucet. The bathroom counter is tile, and the cutout for the plywood is very tight - there is precious little room between the lock nuts, plywood and sink. There is not enough room to apply a basin wrench to the lock nuts.
    What to do? Help?
    Here are some photos (toothbrush for scale, and yes that's an old toothbrush kept under the sink for cleaning :)):
    [​IMG]
    [​IMG]
  2. jadnashua
    Some basin wrenches I've seen would fit.
    But, if you took the water supply lines off and got some really deep sockets, you could probably get them loose that way. They make a fairly inexpensive set of plumbing sockets that should fit.
  4. Terry
    Aug 17, 2004
    Just take a drill and drill out the nut on one side,
    Once you have it split, it will spin off easily.
    Just make sure you have eye protection.
  5. grundy
    grundy New Member
    Jul 26, 2008
    that sounds like a winner!
    thanks for the help.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I often cut the nut with a cut-off wheel in a Dremel tool then put my "Big Kahuna" screwdriver in the slot and twist. They come right off!
  7. hj
    faucet
    That faucet has to drop down to remove it, so you should be working on the nuts on top of the sink.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Redwood slaps himself upside the head and wakes up!
    HJ is correct! Good luck on the topside!
  9. grundy
    grundy New Member
    Jul 26, 2008
    yeah... drops down. which, I figured out after cutting the lock nuts. live and learn. anyway, the new faucet is installed, thanks for the help!
  10. hj
    thankfully
    Phew! I was being told that the old clutch was slipping and was starting to worry about it. Although part of my serpantine belt destroyed itself today, and there appeared to be a squirrel foot among the parts.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    If the squirrel was munching on the belt at least you know it wasn't a lemon! LOL
  12. hj
    belt
    At first it sounded like rocks in the engine compartment and was not sure if it was a tow job or not. Once I got most of the shredded part out, the rest is wrapped around the fan hub, it ran quiet and was able to drive to the dealer without the rest of the belt disintegrating.
Similar Threads: trouble removing
Plumbing Forum, Professional & DIY Advice Having Trouble Removing Vanity Sink Altmans Faucet Flange Jun 8, 2014
Plumbing Forum, Professional & DIY Advice Trouble removing shower/tub trim...see photos May 10, 2014
Plumbing Forum, Professional & DIY Advice Glacier Bay Leonardo faucet, Trouble Removing Handles Mar 20, 2014
Plumbing Forum, Professional & DIY Advice Trouble removing bathroom fixture... Oct 3, 2012
Plumbing Forum, Professional & DIY Advice Trouble removing excess silicone from sink Dec 14, 2011
