Trouble removing bathroom fixture...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pdrmant, Oct 3, 2012.
  1. pdrmant
    pdrmant New Member
    Oct 3, 2012
    Dalworthington Gardens, TX
    I can't seem to find a tool or method that works for untwisting this strange nut.
    It's the one at the right of the pic. One for each handle. Is there some type of tool built for this?
    Thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You do NOT take this type of faucet out/ or apart from the underside. Remove the handle and trim, and there will be a nut holding it in. Take that off and the valve drops DOWN. A photo of the top would help us explain
  4. pdrmant
    pdrmant New Member
    Oct 3, 2012
    Aha... Here you are...
  5. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    use a basin wrench from underneath
  6. pdrmant
    pdrmant New Member
    Oct 3, 2012
    Tried this, but my basin wrench wouldn't get wide enough to grip the "nodes".
    I'm having a little success removing them from the top, as jimbo advised, but the whole section spins.
    As you can see, the faucets are corroded and quite old. I'm having a really hard time getting any twist or progress.
    I've been using vice grips on the geared protrusion shown to hold the unit in place while I use a crescent wrench, hair dryer, wd40 (all I've got at home), and some hammering. Painfully slow.
    Any suggestions for the bolt?
    Thanks.
  7. hj
    Regardless of whether you can loosen the nut on the bottom or not, the top one MUST be removed to take the faucet off the sink.
  8. mfellows
    mfellows New Member
    Mar 3, 2011
    Rochester, NY
    Have you tried vinegar? If you're lucky, it will dissolve most of that corrosion.
  9. pdrmant
    pdrmant New Member
    Oct 3, 2012
    OK, I'll try the vinegar today and see. Anyone give thumbs up on something like Liquid Wrench or some similar product?
  10. hj
    It looks like it is well beyond the "Liquid Wrench" phase. More like a Dremel Tool or hacksaw.
  11. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    By the way, that nut is an electrical lock nut, which should be regular pipe thread. A pair of pliers should be able to grab it, but its difficult to figure out from here if there is enough room to fit in that area. You will have to be careful not to damage the basin, but you MAY be able to jam something like a large screwdriver in there to keep the nut from turning and try turning the valve body again, but as Jimb said, it may not be removable from the top up, as the valve body casting and it port may not fit through the hole. A Fein oscillating saw or cheap knockoff will be able to cut that inlet port off and allow it to fit through the hole Safety Googles are a must here.
    Good luck
  12. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Sawzall......
  13. pdrmant
    pdrmant New Member
    Oct 3, 2012
    Alright. Gonna try the screwdriver in the fitting method and see if she budges. Got a Dremel, too just in case. Thanks for the responses.
  14. hj
    That is NOT an electrical locknut, nor is it a "pipe thread". It is a "proprietary" locknut designed by the faucet manufacturer for THEIR faucet.
  15. pdrmant
    pdrmant New Member
    Oct 3, 2012
    If I were to go at this thing with a dremel, would I first remove (smash) the fitting that's so corroded to get to where I'm beneath the strangely shaped nut at the top. Then cut beneath the nut?
  16. Terry
    Aug 17, 2004
    You will have to remove the top fitting and let the stems drop down. You may be able to use a drill bit to "cut" through the nut. Just a series of holes until you have a cut that can be pried off.
    You may want to score it with a new hack saw blade a few times.
  17. hj
    Cut through the "edges" of the top nut on two sides so it "falls" off the stem, then it will drop through the opening.
  18. BobL43
    Mar 25, 2011
    Long Island, NY
    To a hammer, everything looks like a nail. :eek:
    Still, it looks like some cutting will be involved. On the other hand, if this sink basin is not very expensive, it may just be better to start with a new sink and new faucet. it's easy for me to spend your money, lol
  19. hj
    quote; it may just be better to start with a new sink and new faucet
    If you don't want to bother with dumping the ashtray, you can trade in your car for a new one, also.
  20. BobL43
    Mar 25, 2011
    Long Island, NY
    I don't smoke, but when the car is really dirty, I buy a new one:p Obama says I am entitled to do that.
  21. hj
    quote; when the car is really dirty, I buy a new one
    Yes, don't you just hate going to the car wash and waiting in line?
Similar Threads: Trouble removing
Plumbing Forum, Professional & DIY Advice Having Trouble Removing Vanity Sink Altmans Faucet Flange Jun 8, 2014
Plumbing Forum, Professional & DIY Advice Trouble removing shower/tub trim...see photos May 10, 2014
Plumbing Forum, Professional & DIY Advice Glacier Bay Leonardo faucet, Trouble Removing Handles Mar 20, 2014
Plumbing Forum, Professional & DIY Advice Trouble removing excess silicone from sink Dec 14, 2011
Plumbing Forum, Professional & DIY Advice trouble removing metal rimmed kitchen sink Jan 19, 2009
