Trouble flushing a water heater
Discussion in 'Water Heater Forum, Tanks' started by David212, Apr 9, 2013.
  1. David212
    David212 New Member
    Mar 12, 2013
    Illinois
    I had my hot water re-plumbed due to the copper lines corroding. After everything was done the hot water was discolored. At this point I thought it would be a good idea to flush the tank. I have a traditional 40 gallon tank running on natural gas. I hooked up the garden hose to the plastic drain and opened the valve. All I got was a little trickle of water. I opened the faucet closest to the tank with no change. Normal flow of water out of the faucet. I tried various combinations of having the faucet on/off, cold supply on/off and hot valve on/off. The drain valve is all the way open but the best I could get was 2-3 cups of hot water. What am I doing wrong? Am I missing some step? I get normal water flow from all faucets in the house. After a week of normal use the color has gone away but I would still like to know what I am doing wrong.
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Many of us replace the original drain valve with a 3/4" ball valve when we first install the heater. Think might help, but even then you may need to ream the crud with a piece of coat hanger wire. I've seen sediment so deep even that wouldn't clear the tank.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I've had to remove the valve so I could use a piece of rod to break free sediment blocking the opening in the bottom of the tank.
Similar Threads: Trouble flushing
Water Heater Forum, Tanks Water Heater Recharge Troubleshooting Oct 31, 2016
Water Heater Forum, Tanks water heater troubleshooting Sep 14, 2010
Water Heater Forum, Tanks Trouble Emptying Water Heater Feb 16, 2009
Water Heater Forum, Tanks Whirlpool Flame Lock water heaters, reviews, troubleshooting, repair and support. Nov 19, 2005
Water Heater Forum, Tanks Water heater tank flushing process Jun 13, 2016
