sportsgaleliza
I had a prestige solo boiler prof installed in 2010 and have good luck with it until recently when i got the dreaded E02 error message.
This means ignition problem. The tech came out and said i needed a new igniter/ ignition cable, however, he could not remove the old one because he couldn't get the 2 screws out because of rust. This is after 4 years of use.
Since he couldn't get the igniter out, the tech proposed replacing the entire top plate to the boiler which seems very unnecessary. I have lost faith in him.
I am very surprised that the boiler would start to rust this quickly. Calls/ emails to triangle tube not been returned.
I have tried spraying screws with penetrating oil but no luck loosening them. Any ideas? Ignition
cable and igniter are pictured below (where black and green wire connect). Thanks.
