Trap under slab - concrete over or leave exposed?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeffeverde, Oct 23, 2009.
  1. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    With a bathtub on a slab, is the trap typically left exposed or concreted over?
    I've already installed the (glued) trap, but I'm not sure whether I should box it in and leave it unconcreted, or go ahead and concrete over it, leaving just the stub-out. The tub will be in a platform, so there's no issue with the current install. I'm just thinking about access for future service.
  2. hj
    trap
    "Access in the future" for what? If it is done correctly in the beginning, there is no need for access EVER.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I'd leave access to the trap and trap arm (or a certain amount of it anyway) so that in the FUTURE if you ever want to trade that tub out for something different and it has different dimensions you might be less screwed.
    Leaving access to plumbing is never a bad idea.
  5. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    Everything's tight and solid, but the trap is half in the footing, so a future change/move would be a HUGE PITA if it's all concreted in. Guess I'll be considerate to any future plumber and box it :)
  6. hj
    trap
    You DO NOT have to pour it solid with concrete. Sand fill with a concrete topping is the normal way to do it. And you may be the first person ever to worry about how a plumber would do something in the future and make it easier for him.
  7. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    As a service plumber I love when people consider future re & re's to make our job easier. It also usually ends up saving the person paying some $$$$$.
  8. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    In the state of Florida code requires you to cement it over.
    John
Similar Threads: Trap under
Plumbing Forum, Professional & DIY Advice P-Trap Under Floor Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Need help - p trap broke off, leaving a piece under the slip nut Jan 29, 2015
Plumbing Forum, Professional & DIY Advice Fixing S-trap under kitchen sink Aug 7, 2014
Plumbing Forum, Professional & DIY Advice Leaking p-trap under kitchen sink Jan 19, 2014
Plumbing Forum, Professional & DIY Advice Options in replacing a drum trap under tub Nov 5, 2011
