trap tailpiece minimum length
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by stevenrobertburke, Feb 8, 2011.
  1. stevenrobertburke
    stevenrobertburke New Member
    Feb 8, 2011
    Olympic Valley, CA
    Hi,
    What is the minimum trap-to-vertical waste drop for a 2" tailpience?
    We are in a tight situation for two separate situations. one situation is a shower drain, the other is a laundry drain. Both are 2" ABS and will be located in a crawlspace.i
    Thank you, Steve
  2. jimbo
    jimbo Plumber
    I don't think there is any minimum. You could have the trap arm parallel to and in contact with the base of the shower, sink, etc.
  4. stevenrobertburke
    Feb 8, 2011
    Olympic Valley, CA
    Thank you Jimbo,
    My intent is to avoid an "S trap" Is it ok to go from a 2" ABS trap to a 90 el (outlet is facting down) fitting into waste stack?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The limiting is the distance from the trap to the vent.
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If I read you correctly that IS a s-trap!
  7. hj
    quote; Is it ok to go from a 2" ABS trap to a 90 el (outlet is facting down) fitting into waste stack?
    That is the definition of an "S" trap, so you would be creating one, not avoiding it. And the way you describe it, there might also NOT be a vent for the drain.
  8. jimbo
    jimbo Plumber
    Under the UPC the developed length ( weir of trap to vent opening) minimum length = 2 X diameter.So your length can be quite short, provided it does not drop without a vent opening
Similar Threads: trap tailpiece
Plumbing Forum, Professional & DIY Advice Tailpiece to Trap Rerouting? Sep 18, 2012
Plumbing Forum, Professional & DIY Advice Tailpiece Trap Primer Jan 13, 2011
Plumbing Forum, Professional & DIY Advice P trap and tailpiece too close! Feb 9, 2010
Plumbing Forum, Professional & DIY Advice New Sink: 1-1/2" to 1-1/4" Trap to Tailpiece May 4, 2005
Plumbing Forum, Professional & DIY Advice Opening up P-trap cleanout plug Monday at 5:20 PM
