Trap primer installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by blitziger, Jul 14, 2010.
  1. blitziger
    blitziger New Member
    Jun 29, 2010
    Portland, OR
    Can anyone explain how a trap primer actually works and whether I'm installing the adapter in the right place. I've read here on this forum and elsewhere that the valve is activated by a pressure change. I'm assuming that is a change in water pressure, and I'm hoping that means that there is only a drips worth of water sent to the trap, not a squirt, since that seems like it could waste alot of water over time.
    Thanks.
  2. blitziger
    Jun 29, 2010
    Portland, OR
    I just went to the manufacturers website and found a picture that matches my diagram above so it looks like I'm on the right track.
  4. Terry
    Aug 17, 2004
    You're on the right track.
    They sell 2" couplings with brass fittiings for attaching 1/2" copper pipe for the feed.
  5. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    They work on pressure loss. So when water is used on the piping they're attached to they open up and let a few drips of water out. So make sure you put it on a line you use often enough to keep the trap primed.
    Most people will attach them to the cold water inlet on the HWT so that every time somone uses some hot water they are also priming the trap :D
  6. blitziger
    Jun 29, 2010
    Portland, OR
    Thanks Doherty, I'll aim the primer piping under slab straight toward the water heater location.
    P.S., Saw the pictures you posted for the Naramata Winery. Is that a normal practice to attach the piping directly to the rebar? Are they going to lift the rebar before the pour? All I've seen is around here is putting the pex in first directly on the insulation and the rebar goes on top in the middle of the slab.
Similar Threads: Trap primer
Plumbing Forum, Professional & DIY Advice Continuous Flow Trap Primer Mar 30, 2016
Plumbing Forum, Professional & DIY Advice Trap seal and trap seal primer question Feb 25, 2016
Plumbing Forum, Professional & DIY Advice Running trap primer line for P-trap Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Trap Primer - Advice Requested Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Trap Primer Running Too Often? Aug 17, 2014
