transitioning from galvanized to copper
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jm66208, Dec 16, 2013.
  1. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Gonna tear out some old galvanized and replace with copper. Cant replace it all so I 'm gonna have a 3/4"galvanized to 3/4" copper transition. Figured I'd use a 3/4" brass threaded coupler off the galvanized pipe, then a 6" brass nipple, then a copper FIP to sweat fitting and continue on with my rigid copper. Lotta connections there, but is there a better way? The existing plumbing has some dielectric unions where others have transitioned to copper but they show signs of corrosion.
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Terry
    Aug 17, 2004
    I would not bother installing dilectric unions. They close off very quickly.
    Junk.
    I've been using 6" brass nipples for transistion.
    It's also one reason I don't like leaving any galvanized in a building once I've started replacing with copper. Any time you transistion, it's a probem.
  5. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Thanks Terry, Unfortunately I don't have the option of removing all the galvanized in this situation.
Similar Threads: transitioning galvanized
Plumbing Forum, Professional & DIY Advice Advice for transitioning PVC to non-standard cast iron Oct 10, 2015
Plumbing Forum, Professional & DIY Advice Transitioning DWV Thinwall to Sch. 40 Mar 18, 2012
Plumbing Forum, Professional & DIY Advice Transitioning from PVC outside to PEX inside the house Jan 29, 2011
Plumbing Forum, Professional & DIY Advice Galvanized sink stubout soldered to drain/vent. Or maybe lead piping. Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
