Trane XL80 - gas valve info needed
Discussion in 'HVAC Heating & Cooling' started by Dave2468ca, Jan 17, 2011.
  1. Dave2468ca
    Dave2468ca New Member
    Jan 17, 2011
    Winnipeg, MB
    Hello,
    I have a Trane XL80 furnace with a 2 stage gas burner...The gas valve information is on the inside and I can't read what the resistance from the thermostat should be set at. Mine is set right now at .5 and I find my furnace is cycling very often. It is an older horizontal stat with a mercury bulb.
    What is the proper resistance?
    If I decide to change my stat out...should it be digital, programmable, or does it matter?
    With a 2 stage gas valve on a 80% eff. furnace...is there a particular type of T-stat I should get or something I should stay away from?
    Thanks for all replies.
  2. Dave2468ca
    Jan 17, 2011
    Winnipeg, MB
    Hello...I ended up getting a new T-stat (Honeywell RTH6400D)...the furnace cycling has slowedto a normal rate.
Similar Threads: Trane XL80
HVAC Heating & Cooling Are the Motor Bearings Bad? Trane XL80 Feb 17, 2015
HVAC Heating & Cooling Question on capacitor size on Trane AC unit Aug 6, 2015
HVAC Heating & Cooling New Trane 2stage VS CAC...Ques about wiring Sep 8, 2012
HVAC Heating & Cooling A/C Crankcase Heaters (on a Trane) Aug 16, 2012
HVAC Heating & Cooling Trane A/C System Capacity Reduction Dec 7, 2011
