Trailer Light Switch
Discussion in 'Electrical Forum discussion & Blog' started by Verdeboy, Nov 6, 2007.
  1. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Anyone know the secret to wiring up a trailer lightswitch that comes in its own box?
    I've been "practicing" with some 12 gauge romex, but I can't get the individual conductors to snap into the brass clips. Are these things made for 14 gauge only?
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    God I hate that crap. Impossible to troubleshoot. The last triler I was in, I had to replace a crapload of boxes and regular outlets trying to find a fault.
    I pass on the trailer service calls now.
  4. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    Try some AWG14 and see if it snaps in. If it does, I think you've answered your own question. Since it's a light switch, they probably assume the wiring will always be 14. Lots of "conventional" backstab devices will only accept 14 as well.
    I agree with Alectrician about how hard it is to work on this stuff, but in terms of driving down costs, the manufactured home industry has been pretty effective.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  6. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    It should say right on it what type and gauge wire it will accept...
    That being said, your pic is the first time I've seen the back side of one of those switches... Never dealt with those before.
  7. Verdeboy
    Jun 12, 2006
    It does say that it is rated for 15 amp 120 v. So, I'll have to buy some 14 AWG. to practice with.
    It's similar to back-stabbing, but a bit different. The main difference is that I don't see a release button, so I might not even be able to re-use it once I figure out how to connect the darn wires.
  8. Verdeboy
    Jun 12, 2006
    A lot of people own trailers around here, so I can't afford to pass on those calls.
    One time, I had to crawl under a double-wide to find a loose connection between the two halves of the trailer. There were mice, snakes, skunks, lizards, broken beer bottles, old pizza, dog crap, and every other kind of "trailer trash" you can imagine under there. :D
  9. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Are you replacing or adding this switch? If you are replacing, the wire will still be there for you to reconnect the switch to. If you are adding, why not use a cut-in box and put a regular switch in.
  10. Verdeboy
    Jun 12, 2006
    Replacing. I just wanted to figure out how the thing worked ahead of time, so I didn't look like a complete idiot once I got started.
  11. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Have you tried combing your hair?
    One trick that I try is dressing up but then that would depend on what you were planning on doing.
    I mean one would still look like a complete idiot if they wore a tux to a dicth digging.
    Sometimes looking like an idiot comes in handy, take me for example, no one ever asks me to help do anything so I just stand around looking.... well you know at least I am not the one working their butts off.
  12. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Those special switches and outlets without a real box are sometimes all that will fit in the thin walls in those trailers. The cable is clamped between the two pieces of plastic and you don't need to meet any "box volume" requirements.
  13. Mikey
    Nov 8, 2005
    Consumer
    Looks like the rear half of the case pushes the wire down between the two prong-thingies that go through the insulation and contact the wire, much like communication wiring uses a punchdown block and tool. When you separate the back of the box from the front, you should be able to pull the wires out from the prongs with pliers. Whether the thing is reusable or not I can't say, but I reuse Cat5 punchdown connectors regularly, even the small plastic individual jacks.
    Ca't really tell from the pictures, but it looks like the hard part might be pulling the two halves of the box apart -- those one-way snap-together pieces are a little scary.
  14. Verdeboy
    Jun 12, 2006
    That's actually easy. There's just a couple of tabs that you can pry open with a screwdriver. It's removing the wires from the brass clips that I'm worried about.
Similar Threads: Trailer Light
Electrical Forum discussion & Blog Low-Light CCTV Cameras?? - Budget end of the Price Range. Tuesday at 8:39 PM
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Vanity Lighting Issue Jan 7, 2017
