TP Valve Hook-up
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DBS2071, Aug 7, 2008.
  1. DBS2071
    DBS2071 New Member
    Aug 3, 2008
    Chino Hills, CA
    Well I decided to start this as a new thread instead of keeping the water heater thread going. So...I am now convinced that the TP valve is working correctly and I'm ready to hook it up. I need to run a pipe from the right side of the tank over to the stub on the left wall. My main problem as you can see by the picture is the little stub out. It is sticks out from the wall by about 2 inches and to the from the side of the door molding by about 3/4"
    I didn't want to sweat on a coupling on this stub because if I ever had to cut it off to replace the WH again It would leave next to nothing sticking out of the wall and I wouldn't want to tear into the wall to repair it. So what do you think about putting on a compression coupling on this? That way I wouldn't have to cut the fitting off. Just unscrew it replace the tank and screw the pipe back in. Any thoughts?
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    T & P Drain
    Run Your Copper Over,
    Then Use A 3/4" Sharkbite Fitting As A Union Connection,
    IT IS REMOVABLE LATER IF YOU WANT TO TAKE APART
Similar Threads: Valve Hook-up
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Internal Pipe Corrosion near boiler fill valve. Feb 3, 2017
