towns sewer line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sromes1, Nov 5, 2004.
  1. sromes1
    sromes1 New Member
    Nov 4, 2004
    what is the purpose of a check value? I'm getting city sewer backup and the city suggest this instead of fixing problem in main line. There are roots growing in the main and the tree is a very big willow(most likely) about 100 feet away on private property. The main gets plugged up several times a year and the town says the will just ream it out. If a pipe has already been compromised with roots , wouldn't the reaming process further weaken it. If I put in a check value won't I still get backups(my own) from washing machine overflowing my toilet. Currently I took the sewer cap off in the cellar , so if I have backup it goes there. Then I call the town and they blow up the lines. If I leave the cap on my first floor toilet will overflow and I get all the waste backing up into my living room.The town health board says its not their problem. Any suggestions
    thanks Steve
  2. hj
    sewer
    I would tell the town that it is their problem. In this area if a backup is caused by the city sewer system being plugged, the city will reimburse for any damages, and if you called plumber first, thinking it was your sewer, they will also cover that.
  4. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    A backwater valve will create exactly the problems you have mentioned.
    I am concerned about the sewage in your cellar, this is a real health hazard (although I understand that this is better than in your living room).
    Are you the only one with this problem (there is strength in numbers)?
    If your assessment of the situation is correct, I would get a licensed plumber to give you written verification and start raising h*ll. Regardless of what the town health board tells you, I am certain that there must be some regulation regarding the proper maintenance of the town sewer system.
    This really is an untenable situation that I am sure there is a solution to.
    Deb
    The Pipewench
  5. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    State Board
    It sounds like you live in a small town. They do not always have a clear understanding of their responsibilities and are very budget minded. I would call your State Environmental Health department. This is the town's problem and should not be yours.
  6. hj
    sewage
    The county health board might be the next step above the city/town/village health or sewer department.
Similar Threads: towns sewer
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Sewer smell in apartment, HELP :( Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Where can I tie a 4" branch sewer line in my front yard? Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Sewer smell Jan 31, 2017
