Towel warmer
Discussion in 'HVAC Heating & Cooling' started by rockycmt, Nov 3, 2008.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    I have a towel warmer in my upstairs bathroom on my hot water heating system. It is not getting up to temp as a radiator does in the adjoining room. This warmer is the highest point on the system and I feel it has air trapped up in it. The bottom of it gets warm but the top is cold. Should these have vents on them? What is the best way to resolve this?
  2. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    There should be an air relief in any vertical loops. You may be able to get the air out by running the pump and releasing air in another part of the system but that is hit-or-miss.
  4. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
    Southern man is right on this one. I had a similar issue, one thing I think that helped me get the air out. It sounds like a joke but I think it worked. We got a large electric massager and I had my wife use it on the towel warmer. I surmised that the vibrations aggitated the air while I purged the zone at the manifold. Sounds wierd but I think it worked.
  5. Southern Man
    Jun 27, 2008
    North Carolina
    Any time I can use a large massager on the wife the results have to be good. :)
  6. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    After a closer look, there is a vent. it is a small hex key under the decrative flange against the wall. Will give it a wirl.
  7. Southern Man
    Jun 27, 2008
    North Carolina
    That would be it.
Similar Threads: Towel warmer
HVAC Heating & Cooling Hydronic Towel Warmer Nov 9, 2008
HVAC Heating & Cooling Heated towel rail Sep 25, 2008
