Toto's Softclose Seat
Discussion in 'Toilet Forum discussions' started by Sanz, Mar 31, 2007.
  1. Sanz
    Sanz New Member
    Jun 13, 2006
    NC
    Toto Nexus
    We installed a Nexus toilet and the softclose seat (elongated). The plumber hasn't worked with Toto products before. The seat moves side to side somewhat. We looked at it and the back piece seems to be tight, but the the seat moves. Is this usual for the softclose or is there something that needs to be tightened more that the plumber missed? On another note, this plumber was not happy installing these because they were "different" than the usual American Standard, etc.
  2. SVTour98
    SVTour98 New Member
    Mar 30, 2007
    Yes it is normal for it to move slightly from side to side. The actual mounting hardware that goes onto the bowl should not move, but there is a small amount of play in the seat itself. In the one-page installation instructions for the seat it actually mentions this and says it is normal.
  4. Sanz
    Sanz New Member
    Jun 13, 2006
    NC
    There is no mention of movement in the Installation Manual or instruction sheet that I have. I did notice they mention Anti-skid rubber seat stoppers but they are on the hinge case.
    Does it just take getting used to that movement?
  5. jadnashua
    I've got several...never bothered me. I do notice it sometimes, but not worried about it falling apart or anything.
    Toto has two different attachment bolts - one is a blind attachment plug for the type of toilet that doens't have a clear through-hole so you could attach th enut on the back side and another, more common plastic bolt set. Both of them allow movement some. You could try finding a collar to fill the hole through the toilet, but I don't know if it would help much. toto does make 3 or so different soft-close seats (not counting the colors or round vs elongated). I've never compared them side-to-side. The commercial ones might be heavier duty, but for home use, the standard one has held up fine for me.
  6. Terry
    Aug 17, 2004
    There is a little slack in the hinge.
    It has never been a durability issue.
    [​IMG]
  7. Sanz
    Sanz New Member
    Jun 13, 2006
    NC
    Good to know it's not something unusual. We have an elderly relative coming to stay soon. Wanted to be certain it would not slide too much; the relative has a slight balance problem.
    Thanks for the info.
Similar Threads: Toto's Softclose
Toilet Forum discussions Replacing a wall mounted - what do you think of Toto's wall hung toilet? Mar 20, 2016
Toilet Forum discussions What is toto's closest color to American Standard's Arctic White? Dec 25, 2012
Toilet Forum discussions Wanted Toto's best for Rental Unit Jul 9, 2012
Toilet Forum discussions An alternative to Toto's Soft Close seat? Sep 30, 2010
Toilet Forum discussions What's the big deal about Toto's toilets? Jun 24, 2010
