Toto Vespin toilets
Discussion in 'Toilet Forum discussions' started by betsycapp, Apr 3, 2009.
  1. betsycapp
    betsycapp New Member
    Apr 3, 2009
    What is your rating of the CST764SG? It is a little higher than the regular Drake. i prefer the look if the flushing is as effective, and I need a compact bowl. Any problems with that one? Any better recommendations?
  2. jadnashua
    I have a Vespin and have not noticed any problems in the 5-years or so it's been installed. Hard to do a direct comparison, since I don't use the Drakes I installed at my mother's house that often...my guess, is you'd not be dissapointed with either. I have a Carlyle in my second bath which also works well.
    [​IMG]
    Toto Vespin II CST474CEFG with SS114 Softclose seat.
    This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
    The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
    This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
    Installation was by James Love of Love Plumbing & Remodel 206-949-5683
    In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
    Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
    Everything is on the truck for that.
    The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Any Toto will perform well, so if the Vespin's appearance appeals to you, and it meets your other requirements for size, etc., then that will be a good choice for you.
Similar Threads: Toto Vespin
Toilet Forum discussions Vespin II and Toto parts Sep 19, 2016
Toilet Forum discussions Toto Vespin II 1.0 gpf or 1.28 gpf? Jun 14, 2016
Toilet Forum discussions Toto Vespin vs what plumber knows Aug 17, 2015
Toilet Forum discussions Broke off a flush valve hook - Toto Vespin Aug 20, 2014
Toilet Forum discussions Can I put an toto aqua tank on a vespin bowl? Apr 13, 2014
