Toto unifit on unlevel flange
Discussion in 'Toilet Forum discussions' started by chenry3, Apr 27, 2013.
  1. chenry3
    chenry3 New Member
    Apr 27, 2013
    WA
    Hello,
    I have a basement flange that is not quite level - there is about a 1/3" vertical drop between the left side to the right side of the flange. My original plan was to use 1 (or maybe 2 if needed) sani seal rings on my toilet as I've read that they should be able to handle that amount of unlevelness.
    I've since started looking at the toto toilets (specifically a soiree) with the 10" unifit adapter. I've never used the unifit adapters before and I wanted to know how/if I would be able to use one given my uneven flange. From your pictures at http://www.terrylove.com/wc/unifit.htm it looks like it seals to the flange via bolts the same way a toilet does - but does the unifit use a generic seal or does it have it's own? Would I be able to level out the unift adapter so that the soiree toilet would work or should I loook at a non-unifit 10" rough in toilet with my original idea of making up the vertial difference with my ring seal?
    My other thought was that if the unifit pieces could pivot (I could get one that isn't glued? or cut and re-splice it?) between the toilet and the flange mouting parts I could mount the flange at an angle and rotate the toilet part that joint to be perfectly level for where the toilet attaches. Would that be possible?
  2. Terry
    Aug 17, 2004
    The unifit installs with any toilet seal.
    We've used wax, Sani-Seal and the fluidmaster waxless seal.
    Uneven flanges are more common than you think. We install all day long with stuff like that. And we install the unifit very often.
    We keep 10's and 14's in the van in case we need them.
  4. chenry3
    chenry3 New Member
    Apr 27, 2013
    WA
    Terry -
    Awesome thank you for the info - and the amazingly fast response. Sounds like the unifit will work
Similar Threads: Toto unifit
Toilet Forum discussions Toto Unifit & Water Supply Location Jan 12, 2016
Toilet Forum discussions Problem with Flange Height for install the Toto Unifit Nov 11, 2015
Toilet Forum discussions Other concealed skirt toilets and using the Toto unifit on them May 10, 2015
Toilet Forum discussions Toto Soirée with 13 inch rough in can I squeeze the 14 unifit or stick with the 12 Jan 1, 2015
Toilet Forum discussions leaking toto unifit Aug 28, 2014
