Toto Unifit Installation, wax ring too thick?
Discussion in 'Toilet Forum discussions' started by lordmoosh, Jul 8, 2013.
  1. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Hello all,
    I am installing a Toto Unifit adapter for a Carlyle II. The flange is installed on top of the finished floor. The Unifit appears to only have about 1" of space for a wax ring. The thinnest wax ring I could find at Home Depot (the standard size) looks to be about 2" thick. Is it ok if I trim the wax ring down to about 1.25"? The extra .25" would allow the Unifit to compress the ring onto the flange. Thanks.
  2. Terry
    Aug 17, 2004
    A standard wax ring works fine in that situation.
  4. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    LM: You're overthinking it (which is way better than underthinking it).
    And you want the standard wax ring without the little plastic funnel thingy in it.
    Let us know how your install goes. We have a Carlyle II and love it.
  5. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks, so I should just push the Unifit on the standard wax ring until it crushes it to the flange?
  6. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Well, just like a toilet, you smush it down steadily until it's where it needs to be, then you put the washer on the bolt and spin the nut on (for each of the two bolts) until it's hand-tight, then 1/2 turn with the wrench. Don't wiggle the thing around because wax doesn't spring back, just smush it. (I hope I'm describing it sufficiently to make sense.)
  7. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Yes, thanks!
  8. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Smushing it down worked. Installation was a success. Carlyle II is installed. No leaks or odors detected so far.
  9. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Congratulations!! Enjoy your Carlyle II!!
  10. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    I am noticing one issue. The water level in the bowl seems to be decreasing over time after a flush. I have not connected the sink to the sink drain yet. There is a rag on top of the drain. Could this be causing the issue?
  11. Terry
    Aug 17, 2004
    What do you mean by a rag on the drain?
    Wouldn't that be like a lamp wick, pulling water out?
  12. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    I put a rag on the sink drain pipe so the sewer smell doesn't enter the bathroom (until I finish connecting the sink to the sink drain pipe).
    Anyway I was just working on connecting the sink to the sink drain pipe and someone flushed the toilet upstairs. I noticed the water in the new toilet moving around next to me in the downstairs toilet.
  13. Terry
    Aug 17, 2004
    Kind of depends on how your home is plumbed.
    That's one reason I like to vent toilets, though some codes don't.
  14. jadnashua
    If you have marginal venting in the house, pressure waves in the drain can cause the water in a toilet bowl to rock...same thing can happen if it's really windy. Because a toilet bowl is normally full to the brim, rocking it can cause some to slop over the weir and go down the drain. Since the toilet only knows if the tank is full, it won't refill the bowl. Also, after a flush, the bowl is usually slightly overfilled (not so much on the new ones), and it can take it a moment to settle after the fill valve stops, slightly lowering the level.
  15. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Could cleaning out the main vent pipe help?
  16. jadnashua
    AAV's only let air in, it gets forced closed tighter if there's a pressure wave coming down the pipe.
  17. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    I checked the vent going through the roof. It looked clean. I hosed it down anyway. There was no change. Still losing water in the downstairs toilet when the upstairs toilet is flushed.The upstairs bathroom has a sink, toilet and tub all connected to the main drain which acts as the main vent of the house. Could this happen if the main sewer line is partially obstructed?
  18. jadnashua
    With few very specific situations, and venting between floors isn't one of them, once a pipe is used as a drain line, it CANNOT be also a vent. IOW, your venting system is marginal. May have met codes long ago, but they changed them for a reason over the years.
  19. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Suggestions?
  20. hj
    AAVs do not perform well when used on the fixtures of a lower floor. "Lazy" or "cheap" plumbers use AAVs everywhere they can.
  21. jadnashua
    The proper way to fix this is to tap in a new vent line for the first floor, and run it up to the vent in a code compliant manner - this means either 6" above the flood rim of the highest drain, or 42" above the floor, whichever is higher - or, run a new vent to the roof or attic, then tap into the vent there. This gives a path to equalize the pressure as waste flows down the drainage system. It's tough to share a drain and vent and still have everything work well - it's allowed in a single bathroom suite, but then, only in specific layouts, and never between floors. Newer toilets dump waste faster than the older ones - that big surge is likely causing the issues and is one reason the codes were changed long ago.
Similar Threads: Toto Unifit
Toilet Forum discussions Help - Toto unifit install on tile question Jun 13, 2016
Toilet Forum discussions Any round-bowl Toto toilets w/14" Unifit rough-in? Jun 9, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
Toilet Forum discussions Toto Unifit & Water Supply Location Jan 12, 2016
Toilet Forum discussions Problem with Flange Height for install the Toto Unifit Nov 11, 2015
