Toto Ultramax product review, comments & pictures
Discussion in 'Toilet Forum discussions' started by Reader Review, Feb 7, 2006.
  1. Reader Review
    Reader Review Comments by readers
    Jan 2, 2006
    TOTO Ultramax Eco version MS854114EL 1.28 GPF
    bought a Toto Ultramax ADA height from you a few weekends ago (well not you exactly, one of your workers). The toilet is amazing - thanks!
    C. Honcoop
    Bothell WA
  2. schipperke
    schipperke New Member
    Dec 10, 2010
    Maryland
    Ultra-Max to Eco Max?
    Just received Ultramax to install 1.6g. If I put a brick in the tank, would it work like an EcoMax?
  3. Terry
    Aug 17, 2004
    No. The tank never empties, so placing the brick there does nothing.
    The Eco version has a weighted flapper.
  4. skifvr
    skifvr New Member
    Dec 29, 2010
    Denver, CO
    Has anyone had experience with the Utramax II ADA? I have read many good things about the UltraMax but the only place I have seen anything about the UltraMax II is in Consumer Report and they did not like it. Thanks.
  5. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I have a couple of those (Ultramax II) in my home. Great toilets! If I had to buy another toilet right now, that's exactly what I would get (unless I win the lottery and decide to get the $3000 Toto!)
    The Ultramax II has the "double cyclone" bowl wash, and a great flush. It is actually kind of amazing to watch it effortlessly remove just about anything you can send its way.
    i got the one-piece model and like the look of it and the lack of a gap between tank and bowl. The "MaP" figures show a better capacity for the two-piece, but I haven't had any trouble with the one-piece units getting clogged.
  6. Terry
    Aug 17, 2004
    I sell a lot of the Ultramax II toilets, and they work great. I have one in my main bath.
    CR put a plug in the toilet they shot video of. Any plumber that sees the CR video will tell you, they plugged the toilet, and then shot the video.
    My question is why? Their lawyers have already sent me letters asking me to quit reviewing plumbing products, but guess what, I think a plumber should review plumbing products. I've been in the plumbing business since 1974, it only makes sense.
    Here is a video of how my Ultramax II works.
    [video=youtube;Xn9_zctMge0]http://www.youtube.com/watch?v=Xn9_zctMge0[/video]
  7. skifvr
    skifvr New Member
    Dec 29, 2010
    Denver, CO
    ultraMax II
    Thank you for your feedback and the information you supply to everyone. I wish i was in Washington state so I could get my toilet from you.
  8. photo2010
    photo2010 New Member
    Dec 9, 2010
    CT
  9. Terry
    Aug 17, 2004
  10. photo2010
    Dec 9, 2010
    CT
    Thanks Terry, I'll let you know how it works out.
  11. schipperke
    Dec 10, 2010
    Maryland
    Renovation complete, installed Ultramax Saturday.. not impressed. Plunger was out day #2 .
    (couple extra flushes, bowl filled to the rim..)
    Someone earlier commented the flush was pathetic, I'd have to agree. Does not last long enough to flush the "waste".
    The stoppage was not the result of anything extra ordinary at all....
  12. SteveW
    Feb 11, 2005
    Omaha, NE
    You probably have a partial blockage somewhere downstream from the toilet - perhaps even the wax ring intruding on the toilet flange.
    These toilets are very well engineered - the flush volume is designed to only allow part of the water in the tank to enter the bowl, and it comes in quickly, so it can seem like the amount of time and water is not enough - but it certainly is.
    The toilet needs be pulled and the cause of the blockage found out. It's not the toilet's fault.
  13. schipperke
    Dec 10, 2010
    Maryland
    Ultramax flush
    Good, Bad, indifferent?
    [video=youtube;8XTOA6AhBjk]http://www.youtube.com/watch?v=8XTOA6AhBjk[/video]
  14. Terry
    Aug 17, 2004
    It can depend on the paper used. Charmin has issues I know.
  15. schipperke
    Dec 10, 2010
    Maryland
    Too much TP
    A bit too much,
    courtesy of a 6yo..
  16. gusherb94
    gusherb94 Member
    Jan 13, 2009
    Everything
    chicago/nw IN
    The way that clogged it looks like it stopped at the end of the trapway. If you used a wax ring with a plastic horn it could have been pushed off center when the toilet was set, that would cause it to clog like that. Even if it were installed centered properly, those wax rings with the plastic horn seem to make the toilet more clog prone anyway. That's my guess.
  17. schipperke
    Dec 10, 2010
    Maryland
    I used a thin wax ring, no plastic horn on it. Was kind of strange how it waited a few seconds.
  18. Moshe
    Moshe New Member
    Oct 24, 2010
    ny
    UltraMax II vs. Eco Ultramax
    Hi Terry,
    First off, this site is a lifesaver when planning a modular home!
    My architect has specified the Eco Ultramax because we decided we wanted the larger 3" valve. However, it doesn't have the double cyclone flushing.
    Do you have any insight as to whether the Ultramax II would be a better bet? Would the MaP rating make a difference here?
    Thanks so much!
  19. Terry
    Aug 17, 2004
    I have the MS6041414CEFG Ultramax II upstairs. It cleans the bowl well.
    Tall bowl, Sanagloss, double cyclone rinse.
    I've been selling a lot of them.
    The MaP rating is no help with bowl rinse. The guy that runs that test put in a Caroma and then complained that the bowl is dirty. Everyone knows that the Caroma is harder to keep clean.
    It does have it's good points, but bowl rinse is not one of them.
    The TOTO Ultramax II with 1.28 has been working fine.
  20. Moshe
    Moshe New Member
    Oct 24, 2010
    ny
    Thanks, Terry. But does the Ultramax II also have a 3" flush valve? Does the Eco version really not clean well due to the lack of the cyclone flushing?
Similar Threads: Toto Ultramax
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions Toto washlet seat (s350e) w/Ultramax II or integrated G400? Jan 16, 2017
Toilet Forum discussions Toto Ultramax II model numbers do not match Dec 30, 2016
Toilet Forum discussions TOTO Ultramax One Piece Elongated ADA Toilet slow leak Oct 29, 2016
