TOTO Ultramax II, Gwyneth MS604114CEFG toilet reviews & pictures
Discussion in 'Toilet Forum discussions' started by Terry, Jul 19, 2008.
  1. Terry
    Aug 17, 2004
    [​IMG]
    TOTO Gwyneth MS604114CEFG toilet review
    Made in USA
    Video of performance
    Toto has a new model called the Gwyneth with the WaterSense Ecoflush.
    1.28 gallons, with the double cyclone rinse and Sanagloss in White, Beige/Biscuit and Bone. The Gray and Ebony/Black are without Sanagloss. It comes with the SS114 softclose seat and is the universal bowl height 16-1/8" before the seat is added. MaP testing has given it a 500 gram rating, which in many oppions is plenty for performance. Specs for Gwyneth
    [​IMG]
    Out of the box, the Gwyneth one-piece is a pop and drop installation.
    Pop the box, and drop it on some new wax.
    [​IMG]
    The bowl hase two rinse outlets near the top of the bowl, the water swings around the bowl when rinsing. Toto calls it their "Double Cyclone"
    White, Beige and Bone come with the super smooth ion barrier glazing that they call Sanagloss. I have a bowl downstairs with the same glazing that is 2.5 years old, and it's still very smooth, like the day it was installed.
    [​IMG]
    Inside the tank of the MS604 Gwyneth. It uses the Red Toto 3" flapper, replacements are found at most hardware stores. The fill valve prevents overfilling of the bowl.
    http://terrylove.biz/toilets/10-toto-ultramax-ii.html
  2. funkyd
    funkyd New Member
    Sep 30, 2008
    Ontario
    Updated Review on Gwyneth
    Does anyone have any updated reviews or comments on the 1 piece Gwyneth (with or without Sanagloss). I am very close to purchasing 3 of them for my home reno and just want to make sure that they are as fantastic as they appear to be. :cool:
    Specs for Gwyneth
  4. loke
    loke New Member
    Mar 18, 2008
    Saskatchewan, Canada
    Have had our two Gwyneths since June (Sanagloss) and have had no clogs or problems. One does need to be sure to push the flush lever down completely (no need to hold there, though) as an incomplete push can result in an incomplete flush. Expect that's the same with all toilets.
    I really like the look, too.
    And if you have any concerns about the seat shape - one gets accustomed to it very quickly and I now prefer it to the flat seat on our 1 remaining waterhog toilet. Had some doubts prior to purchasing.
  5. loke
    loke New Member
    Mar 18, 2008
    Should have added that the bowl stays much cleaner than on our old regular style toilets (with the numerous holes under the rim). We'd get mucky buildup quite quickly on the old toilet and that just isn't happening now - maybe in part because these are NEW toilets. But swirling action of the double cyclone and having just the two openings under the rim is definitely good.
  6. GramGram
    GramGram New Member
    Jul 17, 2008
    California
    Just Wondering...
    What are the advantages of this one over Toto EcoDrake besides Sani-gloss and Cyclone flush? I really like my EcoDrake and I'm trying to decide what to use in my other bathroom.
    Thanks,
    Sue
  7. jadnashua
    SanaGlos is super smooth so things have more difficulty sticking and rinse off easier. It also has some antimicrobial properties. Personaly, I think it is a good choice. Some other companies offer similar finishes, but I haven't compared them. I know Duravit makes one they call Wondergloss (or something like that). Most toilets sold in Japan have similar finishes.
  8. loke
    loke New Member
    Mar 18, 2008
    Gram Gram -
    There probably aren't advantages for the Gwyneth over the Eco Drake if easier cleaning isn't important to you and you don't need a one piece. Maybe you aren't the one who has to do the cleaning!
    For me one important advantage of the Gwyneth was that it has about the shortest overall toilet height of the toilets with ADA height bowls - I had to contend with a banjo counter. But if height isn't a concern then there are more options.
    For my 3rd bathroom (basement) I would probably consider the Eco Drake, even with the possibility of more cleaning needed, just because I don't have the banjo counter there and the cost is much less.
  9. Terry
    Aug 17, 2004
  10. Terry
    Aug 17, 2004
    I've been using a Gwyneth one-piece for a few months now.
    The water in the bowl is pretty similar to the Drake and Ultramax, except that there is a bit less volume in the bowl.
    The flush is pretty quick and rinses fairly well.
    The comfort height is nice.
    Specs for Gwyneth
  11. rsmith99
    rsmith99 New Member
    Feb 28, 2008
    Oklahoma
    Gwyneth - Two Piece
    I installed a two piece Gwyneth a week ago and it is working fine.
    It was installed into a narrow space so I opted for the two piece to make it easier to set in place. (Bad Back!)
    The first Gwyneth I purchased was not flat on the bottom and caused it to rock. I took it back and got a new one. This one was perfect. The install went well. The first flush caused a gush of water to shoot out of the bowl and hit the wall. That made me worry. But after that initial flush, it has worked fine. The flush is very fast and the tank fill time is probably about 30 seconds. Much faster than the old toilet.
    The only problem I had was tightening the tank bolts. There are three tabs on the back of the bowl that are supposed to touch the tank when everything has been installed. I tightened the two tank bolts as far as I felt comfortable but there was still about a 1/16" gap on the left front tab. I am afraid to tighten it any further for fear of braking the tank. This is exactly why I would opt for a one piece toilet if I had room to maneuver around to install it.
    I am very glad I purchased a Toto toilet. Much more expensive than the standard toilets but it shows in the quality of the toilet.
    Specs for CST454CEFG
  12. ayeh@pacbell.net
    ayeh@pacbell.net New Member
    Feb 14, 2009
    Gwyneth two-piece
    Hi Terry.
    I ran across your site today and have been studying it. I'm interested in the Gwyneth two-piece. You don't have any reviews yet, but I'm interested in it because I'm in the LA area. Do you think the Gwyneth might flush as well or better as my standard Kohler 1.6 from Home Depot a few years ago?
    Also, is there a reason that you cannot ship the CST454CEFG to LA?
    Thanks,
    Arthur
  13. Hans
    Hans New Member
    Apr 23, 2009
    biochemist
    Oakland California
    new two piece gwyneth
    I just had the two piece Gwyneth sanigloss ADA height (model CST 45CEF) installed, replacing a lovely water hog 1926 American Standard Devoro (not baby Devoro) with a hairline crack in the base.
    The flush on the Gwineth is awesome, and it handles the large masses as advertised. I selected this after much lurking on the website.
    The slow close lid is fun too.
    We had to re-pipe the fill line because the old toilet fill line came in at the top of the tank, not the bottom as in modern toilets.
    We are now noticing a sewer like odor or a urine odor when the bathroom door is closed (no interior fan yet).
    We suspect either a crack in the cast iron drain pipe or a clogged vent pipe or similar ,based on an article in the Ask the Builder
    Sewer Gas Smell
    By Tim Carter
    ©1993-2009 Tim Carter.
    I wanted a second opinion before I called the plumber in for a smoke test.
    Thank you so much for all your help.
    Joey
  14. micp879
    micp879 New Member
    Jul 11, 2007
    Paramedic
    Martinez, CA
    Maybe try a new wax ring? It is possible that when you installed the toilet, the seal provided by the compressed wax ring was broken, allowing sewer gases to seap back into the bathroom from the sewer drain pipe. Have you noticed any water leaking around the base of the toilet?
  15. SanDiegoSue
    SanDiegoSue New Member
    Jun 13, 2009
    Toto Gwyneth not recommended?
    Terry,
    Am curious why the Gwyneth did not make your list of recommendations for toilets "that work in today's world". We just bought one (not installed yet) and now have second thoughts about it as it's not on your list at terrylove.com/crtoilet.htm.
    Which would you say is your favorite Toto 1.28 gpf (considering performance, price, and ease of parts replacement for a DIYer), the EcoUltramax?
    Sue
    P.S. Thanks for the great website and forum.
  16. Terry
    Aug 17, 2004
  17. funkyd
    funkyd New Member
    Sep 30, 2008
    Ontario
    I ended up purchasing 3 Gwyneth once piece toilets and we absolutely LOVE them!
    The universal height is great...except now when i use someone else's toilet it always seems so low! lol The Sanagloss is good and the double cyclone flush cleans very well most times however sometimes you do need to use the brush a bit.
    My only minor complaint would be that the flush is a little bit noisy but only for a second so no big deal.
    Overall I rate this 9.5 out of 10 :)
  18. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    Are the fill valve and flush valve on the one and two-piece Gwyneths replaceable with the Korky parts from Lowe's?
  19. jadnashua
    Toto uses a few different valve manufacturers. One of them is Korky. While you can replace the normal wear part on the Korky supplied versions (cap assembly and flapper) with their parts stocked at Lowes. You may not want to replace the whole valve assembly (not normally necessary anyway). It will work, but they have them made with a custom restrictor to get the bowl to tank water ratio just right to minimize any excess water use dumped down the drain into the bowl.
  20. stark
    stark New Member
    Jul 12, 2009
    New Jersey
    Bowl rinse of 1.28 DC vs. 1.6 DC & 1.6 GMAX
    Hey Terry,
    1) So how does the bowl rinse of the Gwyneth 1.28 gpf double-cyclone compare to the bowl rinse of the Guinevere/Soiree 1.6 gpf double-cyclone? Is it noticeably different?
    2) Would you say the bowl rinse of the Gwyneth 1.28 gpf double-cyclone is better than the bowl rinse of the Drake 1.6 GMAX?
    [video=youtube;Xn9_zctMge0]http://www.youtube.com/watch?v=Xn9_zctMge0[/video]
  21. stark
    stark New Member
    Jul 12, 2009
    New Jersey
    Gwyneth ranking
    So where would you rank it? :)
Similar Threads: TOTO Ultramax
Toilet Forum discussions Toto Ultramax II - 1.0 or 1.28 GPF? Mar 12, 2015
Toilet Forum discussions Need 3 new toilets: Toto Ultramax II or American Standard options Feb 20, 2015
Toilet Forum discussions Any thoughts on the 1.0 GPF TOTO toilets (Drake II and Ultramax II)? Jan 20, 2015
Toilet Forum discussions TOTO - which Ultramax II model to choose Jan 10, 2015
Toilet Forum discussions Terry: I need to buy 3 replacement toilets, which Toto? Drake,Ultramax, Ultramax II? Jan 4, 2015
