Toto ultramax, ADA or not. Rough in ? also.
Discussion in 'Remodel Forum & Blog' started by T_Hartigan, Mar 15, 2009.
  1. T_Hartigan
    T_Hartigan New Member
    Nov 28, 2006
    Doing a bathroom project. Looking at the Toto ultramax with elongated bowl. Having a hard time deciding between the ADA or not.
    Does the 2" height difference make a big difference in comfort?
    Also this is shown as a 12" rough-in. The spec sheet references this as 12" from the studs to center of waste pipe. Is this correct or is it 12" from the drywall?
    Thanks.
    Tim
  2. Terry
    Aug 17, 2004
    The standard is 12" from finished wall to center of drain.
    12" from the finished wall to the center of the drain will leave 3/4" behind the tank.
    It will work at 11-1/4" also.
    ADA height is easier for people with bad joints and sore backs.
    If you have both heights in the home, you may find yourself seeking out the taller bowl.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You might consider this. An ordinary dining room chair is the same height as ADA. I would recommend ADA to anyone except very short people.
  5. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    I have both currently and would like to switch the bowl on the non ADA to the ADA bowl. The next toilet going in will also be ADA as well. The non ADA is like falling into a hole after using the taller one.
  6. T_Hartigan
    Nov 28, 2006
    Thanks.
    This makes my decision easier. :)
    Tim
Similar Threads: Toto ultramax
Remodel Forum & Blog What do you think about the Toto Pacifica Sink? Aug 19, 2016
Remodel Forum & Blog Toto Soirée toilet May 12, 2015
Remodel Forum & Blog Wall Mount Toto Promenade 27" Sink Jan 18, 2009
Remodel Forum & Blog New Bathroom Review - Toto, Swanstone, Moen, Keystone Jul 11, 2008
Remodel Forum & Blog Toto sinks w/sanagloss Sep 8, 2005
