Toto toilet tanks not draining when flushed - flapper issue?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Melissa2007B, Sep 12, 2011.
  1. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    We have 3 Toto 744SL ADA toilets in this house, which were highly recommended here, at the time we built it around 2004-2005.
    We had a rooter guy here last week, snaking a comb out of one of the toilets, and he noticed that the tank wasn't draining all the way, each time it was flushed, and suggested replacing the flapper. He said it should float up until the tank completely drains. The house is only 6 years old but it sounded right, so I went to Ace and got a replacement flapper and swapped it. It still does the same thing. The replacement has "Toto" molded into it.
    So I emailed Toto and they just said:
    "That is correct, the entire tank SHOULD NOT empty out, only half. The toilet is
    operating the way it should. If you hold down the trip lever, the consumption of
    the toilet is no longer 1.6GPF."
    Huh?
    Isn't it "conventional wisdom" ( the rooter guy knew this ) that the full capacity of the tank should empty when it's flushed?
  2. Terry
    Aug 17, 2004
    Your rooter guy is not a plumber. He snakes drains perhaps, but it doesn't make him knowledgeable as a plumber.
    All toilets since 1992 use 1.6 gallons or less.
    That is the conventional knowledge.
    Tanks haven't fully drained now for 19 years.
    If you have a comb in your toilet, using more water wouldn't have helped. Combs are for fixing your hair. Keep the comb out of the bowl, and you should be fine.
  4. mrmedic
    mrmedic Junior Member
    Mar 26, 2007
    Contractor
    Delaware
    This is how they work. Most toilets that I have seen lately work the same way. They need the height of the water to get the full flush but do not need all of the water which is how it saves water from each flush.
Similar Threads: Toto toilet
Plumbing Forum, Professional & DIY Advice Toto toilet differences. Oct 19, 2016
Plumbing Forum, Professional & DIY Advice Toto toilet won't fully flush Aug 9, 2016
Plumbing Forum, Professional & DIY Advice Toto Dual Flush Toilet has started to flush/run every morning at 3:35am Jun 24, 2016
Plumbing Forum, Professional & DIY Advice Toto Pacific Toilet Seat Replacement Mar 7, 2016
Plumbing Forum, Professional & DIY Advice Very slow flush on new Toto Aquia toilet. Bag of installation hardware in outlet (update) Nov 16, 2015
