Toto Soiree TL960SLD Lav Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Terry, Sep 23, 2009.
  1. Terry
    Aug 17, 2004
    [​IMG]
    The TOTO TL960SLD Lav faucet on a 20X17 Toto Lav
    The drain looks pretty solid
    [​IMG]
  2. Ian Gills
    Jul 24, 2007
    USA
    This is all lovely Terry until we see the price.
    So what is the price for this fabulous set?
    $20 per chance? Or 20 times that?
  4. Terry
    Aug 17, 2004
    Don't worry Ian, way more then you would spend.
    It's nice to see something this heavy, wrapped in a velvet bag, and the placed in the box, with a heavy brass drain that has been chromed.
    Not your typical Home Depot stuff with plastic drains and tech support web sites that disappear after you buy the faucet.
    I won't install Home Depot house brands.
    My time is worth more than that.
  5. Terry
    Aug 17, 2004
    Ian,
    This is more your stuff.
    Only eight years old and already rusting.
    [​IMG]
    We also installed three Toto Vespins there, skirted bowls with Sanagloss.
    We removed the Mansfield Alto toilets that Consumer Reports is in love with.
    Yeah right!
  6. Ian Gills
    Jul 24, 2007
    USA
    Question: Why are the polished brass Toto faucets a lot more expensive than the (pictured) polished chrome ones?
    Aren't the polished chrome ones, chrome-plated brass?
  7. Terry
    Aug 17, 2004
    I still don't know why off white is more then white.
  8. Philip in Connecticut
    Philip in Connecticut New Member
    Jan 14, 2009
    Soiree Lav Faucet with 1/2" supply connections???
    It is a nice faucet: I am in the process of installing one as I type this. Funny thing about this faucet: it comes with attached flexible supply lines that have a 1/2" fitting on the end, as opposed to the 3/8" fitting that I assumed it had when I installed my 3/8" supply valves. By any chance, would you know if someone makes a 1/2" male x 3/8" female adaptor with a chrome finish, or do I just use a 1/2" nipple and add an additional length of flex line to go from the 1/2" to the 3/8" (assuming they make a flex line with 1/2" female x 3/8" female)?
  9. Terry
    Aug 17, 2004
    Either change the stops to 1/2" threads.
    Or use a 1/2" pipe nipple in combinations with a standard 1/2" x 3/8" lav supply.
  10. jadnashua
    Polished brass needs a coating of something on it otherwise it will quickly tarnish, so it's likely more steps. Some places use an ion-spatter applied finish that isn't really brass, but looks like it. Again, more steps, more costs.
  11. Philip in Connecticut
    Jan 14, 2009
    OK, 1/2" nipple connecting regular supply line worked just fine. THanks
  12. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    That's a nice set right there.
    That drain is the most solid drain I have ever seen I think. It looks like it would out last most of the cheap crappy houses built today!
    I'd love to install a set like this for a customer to see it in person!
Similar Threads: Toto Soiree
Plumbing Forum, Professional & DIY Advice Toto Soiree toilet problem Sep 25, 2013
Plumbing Forum, Professional & DIY Advice Question regarding Toto Soiree pedestal sink May 29, 2013
Plumbing Forum, Professional & DIY Advice Help! Difference between Toto's Carlyle II & Soiree toilets? Jan 21, 2012
Plumbing Forum, Professional & DIY Advice Persisting Toto Soiree Problems Jul 31, 2011
Plumbing Forum, Professional & DIY Advice Toto Soiree pedestal sink questions Feb 6, 2010
