Toto Soiree Lazy Flush
Discussion in 'Toilet Forum discussions' started by hollywoodgirl, Jan 7, 2013.
  1. lennym
    lennym New Member
    Feb 11, 2010
    nyc
    Thanks for the suggestion. I've had a look at the chain. While there's some slack, there's no question but the lever lifts the flapper to the max. It does not seem like there's water in the float. I have now changed the hole into which the chain attaches on the brass lever rod to the last one. Gives it a very slightly different angle and maybe lifts the flap a bit more. We'll see.
    Does the current Soiree use a float? If not, what? I think I've read on this forum that there are some 3rd party flappers that permit adjustment of the amount of water drop. Time to replace? Any suggestions? Thanks.
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    The Korky 3060BP is an adjustable 3" flapper that would fit your Soiree. Korky is who we recommend on here. It doesn't have or need a float. The new Toto flappers don't use a float.
  3. lennym
    lennym New Member
    Feb 11, 2010
    nyc
    Yes, after all it was the flapper. So I had to buy a new one, and this will be my 3rd in about 3 years. IIRC Toto sent a new one for the first replacement, but not for this one. Following up on the suggestion in another thread, since putting in the second flapper I'm using two rubber washers to center it. I can't figure out why the little arms that hold the flappers are so obviously oversized.
    Anyway I got an adjustable Korky, without the float, and find that it is best at the lowest number (1). The flush can be fine tuned to a small extent using the water level. So three flappers in 3 years, and the need for centering washers. Not a good record for an expensive toilet!
    Just for the record, I also have an 8 year old Toto Carrollton with the original blue flapper that has never had to be changed. Go figure.
Similar Threads: Toto Soiree
Toilet Forum discussions 13-Inch Rough In Question for Toto Soirée Nov 30, 2015
Toilet Forum discussions Instal Toto eco soiree (skirted) if water line is 5.5inches from center? Jul 28, 2015
Toilet Forum discussions Toto Soirée with 13 inch rough in can I squeeze the 14 unifit or stick with the 12 Jan 1, 2015
Toilet Forum discussions TOTO Soiree and Brondell 1000 Dec 28, 2014
Toilet Forum discussions TOTO Soiree lowest flow toilet really works and unifit for 14" rough in is great Jun 28, 2014
