Toto Soft Close Repair?
Discussion in 'Toilet Forum discussions' started by gerlando, Apr 2, 2009.
  1. bighornram
    bighornram New Member
    Aug 29, 2009
    New Mexico
    Turning attention back to repairing the valves for use, I've been googling like crazy. I'm wondering if the resin from an epoxy could be used without a hardener. The original substance seems to be a rubber or silicon based gel with molasses type stringy consistency. Interestingly when I removed what was left, I suck it to a cardboard box. Later that evening it has self leveled and ran down the side of the box. This is like nothing I've seen before. Maybe we can come up with a replacement for this gel and many will be able to repair these things. :)
  2. DECJ
    DECJ New Member
    Mar 25, 2011
    La Sal, Utah
    I guess I am left wondering what causes the failure in the first place. Those who report that the original fluid has leaked out would seem to point to the o-rings or the hinge casing containing the fluid. In such as case, simply replacing the fluid (even if it was the actual OEM fluid), would probably not last as pressure would likely be lost and/or the fluid would just leak out again over time. Obviously, the first hurdle is finding out what exactly the fluid is. If Toto would share the information as to the supplier or vendor who makes the soft close hinges, then we could contact them to at least find out what the liquid is.
  3. bighornram
    Aug 29, 2009
    New Mexico
    I would have no trouble purchasing replacement hinges. I would think replacing the O-rings in the valve would solve the leakage problem.
  4. DECJ
    DECJ New Member
    Mar 25, 2011
    La Sal, Utah
    I dare say most of us would have no trouble purchasing replacement hinges ... if they were available. I am just not willing to buy a whole new seat assembly which is the only route Toto offers its customers.
  5. TSPORT
    TSPORT New Member
    May 1, 2005
    Philly,PA suburbs
    Ever see the movie "The Blob" (the original with Steve McQueen)? Maybe a little piece of The Blob slipped out of the net when that helicopter was hauling it away after they froze it. The piece regenerated into a huge mass but had a change of heart and decided to be useful to the world instead of consuming it and has been donating little pieces of itself here and there so unnamed vendors can manufacture soft-close toilet seats for toilet companies like Toto! How's that for a long sentence?
    OK, seriously, Bemis also makes (or sells) soft close seats sold at the orange big box. Maybe you could contact Bemis and get them to provide some info on the substance they use. -TSPORT
    :D
  6. kevin flanagan
    kevin flanagan New Member
    Mar 24, 2012
    new jersey
    toto soft close repair
    Has anyone tried K-Y Jelly! It is a thick, glycerin base material that can be used for more than you think! :rolleyes: I have had mine apart and seen the material in it, but haven't tried K-Y Jelly until I read the posts and started thinking on a solution. To remove the mechanism you have to slide the stainless shafts out towards the center (carefully spreading the two plastic retainers-careful....don't break), remove the lid and cover, then you can remove the mechanism, remove the two screws, pull the cover off and look inside. You will see the blue wiper blade, I would fill on both sides of the wiper with the KY, then reassemble. Be careful not to damage the "O" rings, and also the small "O" rings on the screws holding the mechanism together. If your mechanism has leaked, check to make sure all the "O" rings are in good condition. Assemble in the reverse order.....Gauge-Guy
  7. ajl
    ajl New Member
    Apr 21, 2012
    Seattle, WA
    Fixed!
    After reading through this thread, I realized I had encountered something very similar to the clear goo in the SoftClose hinge: QuakeHold Gel.
    http://www.quakehold.com/safety-dur...ss-safety-furniture-straps-QHgeldetailQH.html
    It's a clear, sticky, rubbery substance that's supposed to keep glassware from flying off the shelf when an earthquake hits. I had used some for the intended purpose and was dismayed to find that, over time, it would run and drip rather than staying in place under the fragile items on my shelves. It sounded like it would be a perfect substitute for the Toto SoftClose mystery goo.
    So I opened up my SoftClose hinges and wrapped a strip of the QuakeHold gel around the inner cylinder. I put everything back together... and it works perfectly! It's more viscous than the official goo, but I like it that way.
    Hope this helps,
    Aaron
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There do not seem to be too many complaints about the soft close seats. There probably have been problems that were not reported on this forum, but since this is a Toto friendly site, it would be logical to think that we would have heard about them. Sorry the original poster had a problem, but an isolated problem does not mean all soft close seats are bad.
  9. MSTUART1
    MSTUART1 New Member
    Dec 17, 2012
    LONG BEACH CA
    Toto tollit seat hinge fix
    has any one tried hydraulic fluid? Did THE KY Work?
  10. Ethereal
    Ethereal New Member
    Jan 16, 2013
    United States
    My seat went out after 9 months. Just the top lid though. I'm sure that my kids' propensity to push the seat down is what did it. Toto is sending me a replacement seat but I'm going to try to fix it myself anyway. I'll try two fluids: Novagard G662 silicone grease, and a thicker silicone grease that I have for lubricating brake caliper pins. You can get silicone grease in all different viscosities, and I'm pretty sure that's what they would use in the factory.
  11. gldnbrew
    gldnbrew New Member
    Jan 24, 2013
    NY
    Yes they can be repaired. I just finished mine. Took several tries but here is solution. Read the rest of the thread first to see how the closer is taken apart. I tried several thick Silicone greases but here is the one that DOES WORK ACE Brand #4095667 Silicone Grease 90% Pure. Warning this stuff is very sticky and gooey. After cleaning old grease out (not necessary if this is your first time), put a SMALL amount on top of each cylinder and go do something for 10 -15 minutes (it wakes awhile to flow down), when it is all settled down add some more, do this until it is almost up to the top of the cylinders. When this is complete reassemble everything and WALLA a seat that works as good as new.
  12. theob88
    theob88 New Member
    Apr 30, 2013
    BC, Canada
    Thanks for the tip gldnbrew. I purchased two of these seats and one of them failed about about 2 years later. I tried repacking the bad cartridge with vaseline and an automotive grease I have and neither worked. I'm glad you found something that does. I don't know where to buy ACE brand products where I live, but looked it up and it's advertised as an o-ring grease. I found this grease http://www.homedepot.ca/product/silicone-lubricant/910532 on the Home Depot site. It's by Moen and is for valve components but looks to be a similar product. I'll purchase some and see if it does the trick and I'll follow your advice for repacking the cartridge. I'm assuming you reused your o-rings as ones that small are going to be hard to find.
  13. route99capilano
    route99capilano New Member
    Nov 8, 2013
    Alberta
    I am having same problems from Alberta. Did the stuff from home depot work theob88??
  14. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Just discovered my 5 year old Toto soft-close seat not closing softly. Lid part works fine.
    I took the seat off and noticed the one hinge pin, the one for the seat, had somehow pushed its way outside the 2 plastic prongs that are intended to keep it from moving too far inboard (toward the middle).
    I used a small hammer and pounded that hinge pin back into place, and so far seat seems to be working fine now. Nothing wrong with the hydraulics.
  15. Peter Hodgins
    Peter Hodgins New Member
    Mar 28, 2015
    Retired - Formerly with Oil/Gas/Power Generation
    Casa Grande, AZ
    I've just taken one of my seats apart that had given up the ghost after 7 years, and the compound inside has the look, smell and texture of Dow Corning DC4 electrical insulation compound. It's very viscous, holds up well at all temperatures, extremely water resistant and is sticky as the devil! I used to have a tube of it laying around, but I can't seem to find it. I'll have to pick up some and try it.
  16. Norm G
    Norm G New Member
    Mar 29, 2015
    Ontario
    For what it's worth, in my house I have 5 such seats. They were all installed new about 10 years ago. Now they are all failing to close softly. Thanks to the great info here, I will attempt to fix them all.
  17. stuart rhodes
    stuart rhodes New Member
    May 7, 2015
    London
    From a friend from over the pond,I had a similar problem resolved by adding corn flower to silicon grease and making a thick paste, took a few tries until I fond the wright mix ,but its now working fine hope this helps
  18. Geobrick
    Geobrick Member
    Jan 30, 2010
    California
    Do a google search for Silicone Damping Fluid. There are different viscosities so if you find one that works, let us know. You'll get a lot of hits related to turntable tone arms but I'd assume products aimed at that market will be over priced. Try looking for a generic or industrial usage product.
    I think this may be the stuff depending on what viscosity is needed for this application: http://www.clearcoproducts.com/pdf/damping-fluids/NP-PSF-100000cSt.pdf
    Now, where can we buy it in a reasonable size and format.
  19. Kbarb
    Kbarb New Member
    Mar 12, 2016
    California
    I tried the "ACE Brand #4095667 Silicone Grease" that gldnbrew recommended but it didn't work for me.
    I repacked the little cylinders three different times to make sure there was enough grease in them, then put the lid back on causing some squeeze-out. Probably you should fill them and let them sit for 10-15min as advised.
    I could feel some resistance when simulating - that is, revolving the seat's lid away from the mounting bracket by hand.
    But there wasn't enough damping or resistance to do a slow close when the seat was actually mounted back on the toilet.
    And when I opened them up a week later the grease seemed kind of watery.
    It could be that the little blue wipers inside have worn, but I kind of doubt it.
    In retrospect I don't think the Ace Silicone Grease is either viscous or sticky enough compared to what I originally found in there.
    So now I'm thinking to try the "silicone damping fluid" recommended by Geobrick above - although it's expensive - or the KY idea.
    Btw, I couldn't really tell from Kevin Flanagan's 3/24/2012 post - the one who first mentioned KY - if it actually worked for him.
    Kevin . . . you there ?
  20. Kbarb
    Kbarb New Member
    Mar 12, 2016
    California
    Now I've tried KY with no luck either.
    Again, it could be that there is something else wrong, or something I'm doing that's not right.
    Being in a bit of a hurry, I put the KY in with a syringe, starting at the bottom so as to force it into all the crevices.
    I overfilled a bit to cause some squeeze-out, then waited 5 min or so.
    But still it didn't work.
    I'm wondering if there's an ml or two of air in there if it could kibosh the thing.
    It doesn't seem like that's what's going on but I'm wondering.
    But now I'm thinking to try the QuakeHold Gel that AJL/Aaron suggested on 4/21/2012
    ps: for anyone interested in this thread, to subscribe to it and get notifications you have to click "More Options" at the reply screen and click "and receive email notifications" - it doesn't happen automatically.
Similar Threads: Toto Soft
Toilet Forum discussions Toto Drake and water softener Sep 30, 2016
Toilet Forum discussions Toto Pacifica Soft Close Seat Removal Mar 7, 2016
Toilet Forum discussions Toto soft-close seat Jan 6, 2015
Toilet Forum discussions soft close seat for Toto Pacifica Mar 28, 2014
Toilet Forum discussions Toto soft close wood seats? Apr 24, 2012
