rkoo
Ten-year-old Toto (Drake, I think). I replaced the flapper (finally too old and leaky) with a Korky that looks exactly the same, and seems to be the correct replacement. After trying the chain at all different lengths, I absolutely cannot get it to stay open long enough to actually flush (unless I hold the handle down for several long seconds). Please don't tell me that's how low-flow toilets work; I understand that the tank won't clear, but before, even a quick flip of the handle would result in an adequate flush for pee, and a normal push of the handle worked for everything else. Now, the flapper drops shut so fast that there is only about a 2-inch-diameter water spot at the very bottom of the bowl - definitely not normal!
Can anyone help me trouble-shoot this issue?
