Toto Guineveres Just Don't Work, Replace With Drake?
Discussion in 'Toilet Forum discussions' started by slantsixdan, Nov 28, 2012.
  1. slantsixdan
    slantsixdan New Member
    Jan 10, 2010
    Seattle
    Arrrgh! In 2010 I replaced two Crane Drexel toilets from 1950, original equipment in my house, with two Toto Guineveres. The installation craftsmanship was top-notch (thanks, Terry & Co!) but the damn things just don't get the job done, by design. Bowl cleaning isn't just inadequate, it's nonexistent. Multiple "hold the lever down" full-tank flushes and/or a slosh of Simple Green and a scrub with the bowl brush are required each and every time, which eats up (and then some) the savings on reduced water usage. We've tried lots of tricks and tips; nothing's made them work acceptably, and my patience is past its end. I'll be taking my gripe to Toto (again) to see if they'll step up and make good on their philosphy.
    What should I seek as replacements for these Guineveres? How about Drakes, will they really be better? They seem to get good ratings and reviews for both waste removal and bowl cleaning. Does anyone (Terry?) know if they can be had in Toto's #04 grey color?
    Thanks in advance!
    [​IMG]
    Crane Drexel
  2. jadnashua
    Do the toilets you have include SanaGloss? That can really help. It's not available in every color, so that may be the missing part. The II versions of the toilets have the dual cyclone bowl wash, which improves on things, but Sanagloss really does make a difference, regardless. Some peoples' diets can result in very different end results when using a toilet as can how you sit on the thing. Ideally, you sit way back, which directs most stuff into the water spot, rather than the front slope, and that helps keep things cleaner.
  4. Terry
    Aug 17, 2004
    There is not a toilet made since 1992 that is going to replace the 1949 Crane Drexel.
    All new toilets use 1.6 gallons or less. It's been that way for twenty years. If you hold the handle on the newer toilets, you can get as much as 2.5 gallons. But even then, nothing like the swimming pool of the Crane Drexel and the huge water storage tank that goes with it.
    Crane Drexel
    [​IMG]
  5. slantsixdan
    Jan 10, 2010
    Seattle
    I should've asked a simpler, more direct question: Does the Drake have better bowl wash than the Guinevere?
    (point by point: Yes, the Guineveres have Sanagloss. No, those Drexels were overdue when they were replaced, and they flushed sluggishly. Their good bowl cleaning had more to do with their large water pool preventing bowl soiling. And no, it's not a dietary thing; the Guineveres wash inadequately no matter who uses them or what s/he has been eating.)
  6. Terry
    Aug 17, 2004
    The Drake II is similar to the Guinevere in rinsing
    My GF thinks the Drake II is self cleaning, but that's just because it replaced a Glacier Bay. It still needs the brush every so often. What you have now, is like what she has.
    The original Drake is similar in rinsing except that the rinse comes straight down the bowl, instead of swirling.
    One day I got a call from someone talking about a bowl with blades in it. Just the thought of blades was a scary thought. Was he thinking like wiper blades? Or like mower blades?
Similar Threads: Toto Guineveres
Toilet Forum discussions New Toto Guineveres Installed Today... Nov 12, 2007
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Toto toilet seat hinge cover Friday at 4:53 PM
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
