Toto Guinever flapper leaking AGAIN
Discussion in 'Toilet Forum discussions' started by k9, Nov 5, 2010.
  1. k9
    k9 New Member
    Jan 15, 2010
    Phoenix
    Terry can you advise once again please.
    Installed another new Toto Guinever toilet, the first one we installed about 6 month or so ago had the same problem as this one. The flapper is leaking about an inch of water.
    The first one we installed in our house was fixed by replacing the flapper. Toto was great about sending a new flapper out and even sent a proto type for us to try, and thats what did the trick for that toilet.
    Now this new toilet is having the same problem. Is this this the norm? after all 2 out of 2.
    I'm going to see if this one fixes itself over the next couple of days and if not I will call Toto again.
  2. jadnashua
    Wonder if excessive heat during storage might warp the rubber components. Once installed, the water acts as a moderator and the pressure straightens things out, but if it was warped badly before installation, it could be a problem. I've not seen that, but our local temperature extremes aren't as large as they are in a Phoenix summer.
  4. k9
    k9 New Member
    Jan 15, 2010
    Phoenix
    Its still leaking a inch of water, I know it was shipped from California though. Im going to call Toto Monday to see if they will send me another proto type flapper.
  5. k9
    k9 New Member
    Jan 15, 2010
    Phoenix
    OK Toto is sending me a new flush valve and flapper.
    Long ago I posted when I had this same problem, Terry mentioned to check to see if there were any bumps under the FV Seat. So I checked and sure enough there are 3 bumps of the white porclin drips.
    I tried to use emory cloth to get rid of them to no avail, That stuff is hard.
    Any other advice?
    I have filled up the tank just to the bottom of the flush valve to see if thats where it leaking.
  6. Terry
    Aug 17, 2004
    If emory cloth and reinstalling doesn't work, then silcone caulk should work under the flush valve.
    You will know soon enough.
    Once the tank is full, turn off the water and see if the level drops.
    If the water drains out lower then the flapper, then it would be the seal under the flush valve.
  7. k9
    k9 New Member
    Jan 15, 2010
    Phoenix
    will do
    thank you
Similar Threads: Toto Guinever
Toilet Forum discussions Your recent Toto Guinevere experience? Jun 29, 2014
Toilet Forum discussions Guinevere Toto toilet - too tight space creating problems - ideas to fix welcome! Pl Nov 16, 2013
Toilet Forum discussions Toto Guineveres Just Don't Work, Replace With Drake? Nov 28, 2012
Toilet Forum discussions Toto Guinevere tank filling past overflow tube Jan 7, 2012
Toilet Forum discussions Retrofit a 1.28 Toto Guinevere to 1.6+? Nov 25, 2011
