Toto fill valve leak
Discussion in 'Toilet Forum discussions' started by Maverick_54, Nov 2, 2010.
  1. Maverick_54
    Maverick_54 New Member
    Nov 2, 2010
    South Carolina
    My toto toilet fill valve drips at a constant rate approx. every two to three seconds into the overflow. I could use assistance on how to fix the problem. Thanks guys.
  2. jadnashua
    Toto uses several different fill valves. If you have the one made for them by Korky, stop at Lowes or a local plumbing supply shop for a replacement cap (around $3), and in about a minute, you will have replaced the only seal in the thing. If it is not the one by Korky, then you have to replace the whole thing, as far as I know. You might want to check the static incoming water pressure. If it is excessivly high, you may need a PRV and expansion tank. A toilet fill valve seems to often be one of the weakest links, and leaks first under high pressure situations. If you are lucky, you could just remove the cap, check if there is any sand or other thing preventing the seal - clean it off, then replace it and solve your problem.
  4. Maverick_54
    Nov 2, 2010
    South Carolina
    Thanks Jim. I appreciate your response. Thanks alot. Have a nice evening.
    Randy
  5. RickW10
    RickW10 New Member
    Nov 3, 2010
    Chicago, IL
    I have the same issue. We just switched from well water to city water and the pressure is greater, not a lot greater, but greater. The only location where it seems to be a problem is at my Toto toilet where after the flush, the water shuts off, but then after a few hours, it starts dripping. In searching this site, I see the comments about installing a prv. Are there prvs that I would just install at the toilet? The only ones I see at Home Depot are quite large and seem to apply for the whole house. Any thoughts? Thanks
  6. jadnashua
    If you have a water pressure issue, you install one for the whole house. Generally, anything greater than 80 pounds should have one and it generally requires an expansion tank as well. Note, some places install a check valve on the inlet to the water supply to your house. In this case, you need an expansion tank to account for when the WH runs and heats up the water, expanding it.
Similar Threads: Toto fill
Toilet Forum discussions Toto CST703 refill valve replacement - no refill tube Mar 13, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toto CST416 refill is not consistent flow Jan 9, 2017
Toilet Forum discussions Fill valve for Toto ST701 Aug 20, 2016
Toilet Forum discussions Toto Promenade Fill Valve 2016? Jul 26, 2016
