Hello. After needing to replace the flapper about every 12-18 months, I decided to try the newer flush tower drain valve. The silicone seal should do better in my water (at least I'm hoping so).
Does anyone know the proper setup for this? Should the flush rod be bent over the top of the tower to pull the mechanism straight up? The rod already bumps the front of the tower on the way back down because it rests a bit lower than the top of the tower. If I bend it on top, it's going to rest on and hit the tower. It seems unlikely that the handle is worn and the rod is sitting too low, but I guess it's possible.
It flushes ok with the setup shown, but doesn't seem ideal. Thanks.
