Toto Eco Drake Problem
Discussion in 'Toilet Forum discussions' started by JPW, Feb 4, 2010.
  1. JPW
    JPW New Member
    Feb 4, 2010
    Westminster, CA
    I installed the Toto Eco Drake in our master bath a year ago. It's been a great toilet and has never clogged. However, the fill rate has slowed to a crawl, and it can take up to 5 minutes to fill the tank.
    I've tried getting into the E-Max flush system to look for and clean debris, but I can't seem to figure the darn thing out. :mad: Can anyone point me in the the direction of an online PDF diagram of this unit, so I can fix it?
    Thanks for the help.
    Jeff
  2. Geobrick
    Geobrick Member
    Jan 30, 2010
    California
    I had a similar problem (not with a toto). It turned out that the braided flexible pipe that connects to the stop valve had small pebbles stuck in it. It probably happened after the water company was working on the main supply in the neighborhood. If you haven't aready checked that, I'd recommend you take a look at it.
  4. jadnashua
    Toto uses a couple of different fill valves. Does yours have a screw on the top? If it does, that one can't be taken apart (as I understand it). If it doesn't, squeeze the top and the blue part pops off, then you can disassemble it and check the filter. It's made by Korky, so you can view the instructions on their website. if you search, it's here as well.
  5. JPW
    JPW New Member
    Feb 4, 2010
    Westminster, CA
    Mine is the E-Max system, is elongated, and has a screw. I popped the top off, but couldn't figure out how to remove anything else to check for debris. I'll check the supply line and see if there's debris there.
  6. dunstergirl
    dunstergirl New Member
    Oct 30, 2007
    British Columbia
    Did you ever find a fix for this? I have the same problem and the same unit.
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
