Toto Eco Drake - loud flush "finish"
Discussion in 'Toilet Forum discussions' started by lookingforquietplumbing, May 15, 2009.
  1. lookingforquietplumbing
    lookingforquietplumbing New Member
    May 15, 2009
    Has anyone else noticed that after the Toto Eco Drake's flush is finished it has a loud "shquwap" noise. It's right at the end, after the tank has filled back up. I'm thinking it's the water turning off?
    At any rate it's quite startling and I'm hoping someone can tell me how to fix it, or can tell me that they replaced a part(s) and it is not quiet.
    Or maybe someone out there has another 1.28 GPF toilet that works as well as the Eco Drake only more quietly.
    For anyone else who wants a quiet toilet the Toto Aqua is near silent (big or small flush) and it works great! - but personally I prefer the Eco Drake's 14 5/8 height over the Aqua's 15 1/4 inches.
    Thank you for your help!
    Charles
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    The loud gulp that you hear is the vacuum being broken as it starts sucking air since the water is now too low ... I would think there is a direct correlation to the volumn of this gulp and the strength of the flush. That's a good thing:D
  4. micp879
    micp879 New Member
    Jul 11, 2007
    Paramedic
    Martinez, CA
    Hmmm, Im not so sure about that 99k. He says the sound is made right after the tank finishes filling back up, not at the end of flush itself. To me it sounds more like an issue with the fill valve maybe making some type of noise after it shuts off from filling the tank.
  5. jadnashua
    The older fill valves made by Korky for Toto are pretty quiet in operation. I've not experienced the newer style, so can't say. I'm not sure the older ones can be tweaked to balance the tank/bowl volumes to meet the 1.28g flush. A stock valve from a big box store will work, but the balance between the bowl/tank won't give you the stated flush volume.
  6. 99k
    Aug 16, 2008
    Yeah I agree with you ... I skimmed it too quickly. Perhaps a hammer.
  7. lookingforquietplumbing
    May 15, 2009
    maybe i'll try the hammer :)
    thanks for the suggestions...maybe I'll try the hammer...now to find the fill valve...
    thanks again
  8. spiffee
    spiffee New Member
    Sep 12, 2009
    san diego
    We are having the same problem.
    We just installed a new Eco-Drake elongated and are getting the loud slupring noice both at the beginning of the flush and the end of the flush. Does anyone know if this is normal or did we happen to get a defective unit? Any help would be greatly appreciated!
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
