Toto Dual flush - not filling
Discussion in 'Toilet Forum discussions' started by dpw-ct, Dec 27, 2013.
  1. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    I have had a Toto Aquia® One-Piece Toilet, Dual Flush toilet (1.6GPF & 0.9GPF Model MS654114MF) for a couple of years and all of a sudden it stopped filling. Any advice on what this might be. Sediment ? other common causes. Need advice on how to fix.
    Thanks all
  2. Terry
    Aug 17, 2004
  4. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    If after servicing the valve it doesn't solve the problem, turn off the water to the toilet, disconnect the supply hose from the valve, and holding the hose over a bucket or something turn the water and see if any comes out the hose in a good flow. If not, then you may have a defective FloodStop hose (that is supposed to cut off for excessive flow). Replace it with a normal hose and you should be fine.
    Korky video on servicing the valve (Korky makes the green-capped fill valve that Toto uses in the Aquia):
Similar Threads: Toto Dual
Toilet Forum discussions AS Vormax vs Toto Drake II vs AS H2Option Dual Flush Jan 23, 2016
Toilet Forum discussions Toto Dual Max 0.9 flush? Jan 4, 2016
Toilet Forum discussions American Standard Dual Flush or Toto Entrada? Nov 11, 2015
Toilet Forum discussions Recommendations for new toilet: Toto Drake or a dual flush? Nov 9, 2015
Toilet Forum discussions 1-piece, dual flush: Toto Aquia or AS Boulevard? Feb 23, 2015
