Toto Drakes pulling water from each other's bowls
Discussion in 'Toilet Forum discussions' started by flushed, Jun 18, 2005.
  1. flushed
    flushed New Member
    Jun 18, 2005
    Missouri
    We just installed two Toto Drakes that sit back to back in adjacent bathrooms. I'm experiencing the symptoms described on http://www.terrylove.com/wwwboard/messages2/42893.html
    That review was part of my rationale for not buying the American Standard.
    The flush does not pull all of the water from the nearby toilet's bowl, but enough that the next flush would appear to be "incomplete" at best. I have checked the rooftop vent for any clogs and have found none.
    Does anyone have any thoughts or suggestions?
  2. Terry
    Aug 17, 2004
    I would think it to be the plumbing.
    I've seen plenty installed back to back without problems.
    In fact most homes plumb the toilets back to back.
    If you have a San Cross fitting, the water can skip across the fitting, pushing air and displacing water in the opposite bowl.
    Most high performance toilets require a fixture type fitting.
    [​IMG]
  4. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Flushed
    I've experienced your situation. Contact Toto. They are aware of the problem. It occurs when the wcs are plumbed using a 3' figure #5 or doulbe fixture type fitting. They recommend a double combo setup. Unfortunately, a double combo with 2 90s might have a longer spred then the 30" to 32" common in back to back setups.
    Fortunately my problem was not over a slab. I was able to cap one side of the fig 5 and connect one of the wc's to the lavy riser, turning it into a wet vent. Lucky for me I ran it 2" rather than 1-1/2".
    Scott
  5. flushed
    flushed New Member
    Jun 18, 2005
    Missouri
    Thanks for the advice. I think I'll try talking to Toto.
  6. srdenny
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Looks like you have the room to put in a double combo. Check with Toto first, but I think you can get out of this one with your pants still attached.
  7. Terry
    Aug 17, 2004
    In Washington State they never would have allowed a sanitary cross for two toilets.
    They do allow a double combo
    [​IMG]
    A double fixture fitting
Similar Threads: Toto Drakes
Toilet Forum discussions Differences between Toto Drakes CST744EL#01 and CST454CEFG#01? Apr 8, 2015
Toilet Forum discussions hard water and toto aquia II-III or drakes Mar 1, 2009
Toilet Forum discussions Installed 2 Toto Drakes - question about flushing... Aug 1, 2008
Toilet Forum discussions New Toto Drakes Apr 30, 2007
Toilet Forum discussions Do all Toto Drakes have sanigloss Jan 3, 2006
