I have two Toto Drake toilets, one with a round bowl, the other the ADA elongated bowl. Both tanks seem to read st743s. Recently I had an issue with factory fill valve on the elongated bowl toliet so I ordered the universal toto fill valve (tsu99a.x) for it. I installed it and noticed some things that I have questions on -
1) I set the new valve to peg 5 for tank water level and fill level around 3. I noticed the tank water level is now almost at the top of the overflow tube, is that OK?
2) Right near the little fill adjustment valve after a flush and when water is going through the little line, a few drops of water appear on the blue plastic cover below the little fill control, this appears to be from the connection between the fill valve and the flow control where the plastic hose connects to the flow control. Everything looks tight and it's just a bit of water but will this hurt anything or cause of concern?
3) On my other Toto I have the old valve still with it's manual turn water level adjustment, where should the water level be? The writing on both tanks is not legible where it say's how far below the fill tube it should be.
4) Does anyone have a picture or something to help me determine the where the water level in the bowl should be at?
Thanks
Thanks
