Toto "drake" toilets parts ?
Discussion in 'Toilet Forum discussions' started by catraveller, Apr 5, 2005.
  1. catraveller
    catraveller New Member
    Apr 5, 2005
    We have 3 of them installed in our house 2 yrs ago. One of toil tank refills to non-stop overflowing after a flush. Where can I buy replacement parts ? ( I assume it is the G-max mechanism.)
  2. Terry
    Aug 17, 2004
    [​IMG]
    Korky makes the fill valve found at many hardware stores.
    Quietfill valve
    Sometimes replacing or cleaning the assembly cap does it.
    www.terrylove.com/korky
    Parts can be found at any Lowes, including the red and blue flappers fro TOTO made by Korky.​
  4. catraveller
    Apr 5, 2005
    thanks
    Thanks for the pointer.
    can this
    Hunter / Korky Quietfill / TSUO4A.5 / toilet tank fill valve
    completely replaced the TOTO part ?
    I had expected there are some magic to Toto G-max system.
    Will this part still provide the power flush in the Toto Drake toilet ?
  5. Terry
    Aug 17, 2004
    The parts interchange.
  6. jadnashua
    The filler doesn't make that much difference - it is the design of the waterways when you push the lever to flush that makes the difference, filling the tank back up at the end is sort of anti-climatic. Note, the right flapper valve does matter - get the wrong one and it may not use the right amount of water, defeating some of the water saving design or performance. Course, some brands use different sized holes and other brands/types of fillers won't work on a particular toilet. My unprofessional opinion.
  7. catraveller
    Apr 5, 2005
    good explanation
    Thanks for the clarification.
    I will go get this part and hope to solve the Toto Drake overflow problem.
  8. catraveller
    Apr 5, 2005
    thanks
    I bought and installed Korky Quietfill fill valve in the Toto Drake toilet, solved the overfill problem.
    This part are so close to the Toto orig that the Toto cap fit over the valve.
Similar Threads: Toto drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Yesterday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
