Toto Drake toilet product review
Discussion in 'Toilet Forum discussions' started by Reader Review, Jan 27, 2006.
  1. wired711
    wired711 New Member
    Sep 28, 2009
    Philadelphia
    Great review RWB - helps make the case for anyone (including me) weighing a 1.28 Eco Drake against 1.6 Drake for pure performance reasons. Please keep us informed as time and usage goes on!
    Wired
    [​IMG]
    TOTO Drake 800 grams by Veritech, Video
  2. romumok
    romumok New Member
    Oct 19, 2009
    So Cal
    Interesting observation
    Hello All. I am newby here.
    I just got installed a Drake Elongated ADA toilet to replace an OK Eljer Patriot 1.6 gpf per Terry’s recommendations. The Eljer was able to handles all my needs but I got tired of wasting extra water in a second flush to completely clean the bowl. Most of the time there are always some residues left behind. But the main reason is that my wife always clog the toilet as a result of one of her side effects of being pregnant i.e. constipation. So as a devoted husband, I have to unclog the toilet every time she uses it. :eek:
    There is the interesting observation. I will describe it without too grossing you out. After the install, everything is so far so good. The Drake has a powerful flush, water doesn’t splash out compared with the Eljer. So far I am happy. The next day I took the toilet for a real world test flush. Once done, I push the lever and whoosh! Everything there is gone!. I was happy until my wife had to go. After a short time, my wife calls me and said she clogged the TOTO. Yep, she did it. :eek:
    She made the mistake of trying of flush again and the water level was about 3 inches before spilling out from the bowl. No problem, I pulled out the plunger and began to work. Nope! It didn’t bugged. Tried again and still nothing. Definitely is not excessive paper. So I pulled my little hand crank auger and once I inserted it about a foot, I felt the obstruction. Apparently, two chunks of solids got wedged side by side plus some paper made the toilet clogged. So, I just pushed the obstruction a bit and next thing there was a big whoosh! Everything went down to the drain. I was really surprised since it was a first time I have seen this. Other toilets will flush but not as powerful as I have seen when gets unglogged. I have to say, the trapway design is very efficient without any tight turns.
    My wife felt bad that even we spent a good amount of money for a good toilet she still able to clog the toilet. I told her not to worry that could be an unusual situation. To end this story, I just got a call from my wife. She told me that this time NO clogged TOTO toilet! Yey! Everything went down with a single flush! Now she is happy. Therefore, I am happy.! :)
    cheers!
  3. Terry
    Aug 17, 2004
  4. dmt9544
    dmt9544 New Member
    Nov 7, 2009
    Olathe, KS
    Is there a similar model to the Toto Drake that is 16" to 17" high?
  5. glnow
    glnow Member
    Mar 7, 2007
    CA
    What is the brown material used in that video? I mean, she's touching it without gloves, so it can't be what I'm thinking.
  6. Terry
    Aug 17, 2004
    It's a bean paste.
    They get it from a restaurant supply.
    [​IMG]
    2Bgreen's TOTO Drake
  7. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    So you don't believe she took the time to "roll her own" and figured she didn't need to worry about germs because it came from her anyway? :D You just can't fool some folks...
  8. Reader Review
    Reader Review Comments by readers
    Jan 2, 2006
    Dave in Bothell
    Hello guys,
    The toilet in the master bath works fine; great job once again - thanks.
    Dave in Bothell
  9. yaozer
    yaozer New Member
    Nov 21, 2009
    NJ
    Johnny Seal
    Hi everyone,
    Thanks for your feedback on this toilet. I can't wait to install it. The Johnny seal that the plumbing store gave me for my new Toto Drake seems a bit thin or more low profile than the regular rings (about half the thickness). Do Toto toilets use thinner rings to seal the base?
  10. jadnashua
    The wax ring needs to be thick enough to squish when you set the toilet. Each situation is a little different. Depends on where your flange is and the toilet to determine the thickness needed.
  11. Terry
    Aug 17, 2004
    The Toto Drake is the best two-piece toilet.
    It has a consistent rinse and flush.
    Parts are easy to get.
    Less then 1% defects, which is almost unheard of in the industry.
    The Sanagloss option is nice too for even better cleaning.
    The bowls are flat on the bottom.
    And they will cover most old footprints, which is a real plus when replacing toilets.
    A good solid flush, with little noise.
  12. dholling
    dholling Dave
    Dec 23, 2009
    PA
    Installed a new Toto Drake - took out one builder grade "toilet"
    Terry,
    Thank you very much for your web site. After much research on your site and others, I went with the Toto Drake to replace one of our builder grade "toilets".
    I installed it myself and then planned some tests. The hardest part of the install was taking out the older toilet. The Toto was a very easy install. I can consistently plug up industrial grade toilets. The builder's grade toilet that I replaced required a plunging each time and 3-4 flushes. To test the Toto, I did my best, and included a lot of paper. Swoosh, glug, glug. ONE FLUSH!
    By the way, I emailed Toto to get two color chips to get an exact match on the color in our bathroom. Toto sent the chips the next day. Other manufacturers required that I pay for the color chips, make other phone calls to other departments, etc. - not!
    I will be replacing my other toilets in the house with Toto Drakes.
    Thanks again,
    David
  13. stalag
    stalag New Member
    Jan 5, 2010
    Columbus, Ohio
    replacement of sterling toilet (kohler) with Toto Drake
    I did a bit of research before requesting permission of my landlord ( I live in an apartment) for replacement of my toilets with ADA compliant toilets. The toilet I had in my last apartment were American Standard toilets and in my current place they were round Sterling toilets. Neither brand worked well for my purposes and the American Standard toilets were very prone to clogging and the round sterlings barely letting me do both #1 and #2 simultaneously without urine on the floor. Being a big guy with some current health issues I had the need for an elongated ADA replacement. After some digging I found this site where I read the reviews and after receiving permission from my landlord I bought the toilet from a local plumbing supply house. The apartment maintenance who installed the toilet had never experienced the toilet before and when testing the toilet was shocked at the quick flush. I am so far happy with the performance of the commode and have stopped using the other bathroom in my apartment that has a sterling still installed in the bathroom. I would recommend this toilet to others who have need of a good solid toilet.
    stalag
  14. Presto
    Presto New Member
    Jan 7, 2010
    Erath, Texas
    Happy but.......
    I installed 2 Drake CST744SG's barely a year ago and really like them. A couple of problems though. The chrome on flush knobs are bubbling and the plastic "spud" that goes through the tank holding the flush knob on one of them has broken where the nut threads on. I just got done speaking to Toto tech and they are sending the parts, as a courtesy! Not covered under warranty. I would expect these items to have a better design life for the money!
  15. Runs with bison
    Aug 23, 2009
    Midwest
    Presto, has anyone used any cleaning materials that might have caused the bubbling (as in anything other than simple soap and hot water?) If so, what material was it so that I can avoid the problem? Thanks!
  16. TSund
    TSund New Member
    Aug 23, 2008
    TX
    having problems
    Hello,
    We installed an Eco-drake in our lake house and loved it so much that we decided to replace our home's masterbath toilet with one. That toilet had frequent cloggin problems, remedied with a plunger.
    My dad installed the toilet, and noted that the the drain is put on a Y. He said that is due to mismeasurement by contractor?
    I don't know if this is the cause of the problem, but I need to do something. We still get frequent clogs. I need a recommendation. Will raising toilet up help? Would the flapper modification be the same as replacing with a regular Drake? If I"m to replace another toilet in the house on the 2nd floorm should I switch this one with a more powerful flush? Looking for most cost effiecient way to do this, but WANT the problem solved.
    I so appreciate your help. I am bummed about this. I guess I wouldn't have put in the smaller eco-drake if I"d known about the Y in the drain.
    THanks
    TRS
  17. Terry
    Aug 17, 2004
    I would pull the bowl and make sure there is nothing blocking the exit.
    The directions on the box of wax, show the wax stuck to the "bowl".
    Plumbers put the wax on the "floor" and then drop the bowl on that.
    Also, some horn wax rings will flatten out on some flanges.
    There is a high rise in Bellevue, where the entire building was plumbed with Sterling toilets and the small closet flanges.
    We're changing out the building bathroom by bathroom with Toto toilets it seems. And not using the horned wax there.
  18. Reader Review
    Jan 2, 2006
    TOTO Drake CST744S
    Dear Terry.....I've personally installed a dozen Toto Drake 1.6 gpf toilets in my rentals and for family. They are great low flow toilets that really work as you have indicated.
    I've come across a new Toto Eco Drake 1.28 gpf with a E-max flush system.......Do you have any thoughts or experience on this toilet?
    Thanks/Rick
  19. Reader Review
    Jan 2, 2006
    TOTO Eco Drake CST744E
    The toilet is working great. Thanks!
    Jodie
    Redmond WA
  20. Reader Review
    Jan 2, 2006
    TOTO Drake CST744S
    We bought a 1.6 gpf Toto from you a few years ago. It works very well. We are now considering getting another Toto. I see there are now some 1.28 gpf totos on the market: the CST 743 and 744.
    Do these 1.28 gpf totos flush as well as the 1.6?
    Thanks
    Don T
    Olympia
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
