Toto Drake Slow Tank Refill
Discussion in 'Toilet Forum discussions' started by mala88, May 31, 2007.
  1. mala88
    mala88 New Member
    May 31, 2007
    Hi,
    I just replaced one of the toilets in my house with a new Toto Drake. It works great, except for the fact that it takes almost 2 minutes to refill the tank after a flush. I replaced the water supply line but that didn't help. Any ideas on what could be wrong?
  2. jadnashua
    Is the shutoff valve fully opened? Another thing to try is take the filler apart, depending on which one you have, it is usually easy, and see if there's any debris in the filler. If there is, it often causes it to be unable to shut off, but it depends on where it might be. The shutoff valve, if old, could have the washer breaking up and plugging the line. If you take the hose off of the filler, try directing it into a bucket and see how well it flows.
  4. Older Woman
    Older Woman New Member
    Feb 26, 2011
    CA
    I have same problem with different toto toilets at different times. It can take a verrrry long time to refill then correct itself for a month or more than start again. Any tips?
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
