elgato
I purchased a Toto Drake from a local plumbing supply. The Drake 2 was tempting but I decided to stay with the Drake 1 just for the 1.6 gallon Gmax. The bowl is a C744EL.
As I was about to install the tank I noticed that it is a 1.28 gallon (ST743E)
Does the combination of the C744EL and the ST743E make this an Eco-Drake?
My options are:
1. Keep the ST743E 1.2 gal tank.
2. Winnelson said they no longer stock the ST743S 1.6 gal tank but could order one in for an additional
charge plus freight.
3. Winnelson said that they could request the 1.6 gallon fill valve and flapper from Toto to make this tank
into a 1.6.
4. Pull it out and simply buy a Drake 2.
If I knew that I was getting a 1.2 gal Drake, I certainly would have went with the Drake 2 which has CEFIONTECT.
Is there much of a performance difference between a 1.2 Drake and a Drake 2?
So, which of the above makes the most sense?
Thank You
My options are:
into a 1.6.
Thank You
