Toto Drake Leaking Under Tank
Discussion in 'Toilet Forum discussions' started by Mike_D, May 21, 2012.
  1. Mike_D
    Mike_D New Member
    May 21, 2012
    Halifax, Nova Scotia
    I have a Toto Drake and noticed that it was leaking slowly where the big white nut contacts the bottom of the tank. I tightened it and it seemed like it was fixed but 12 hours later it was still leaking. I don't want to tighten it too much in case it cracks the tank. There seems to be something wrong with the seal in that location I would assume. Would it be best to take the whole assembly out? Any advice would be appreciated.
    Here's a picture :
    http://img23.imageshack.us/img23/981/20120521064543.jpg
    [​IMG]
    Thanks,
    Mike
  2. Terry
    Aug 17, 2004
    I would spin the nut off and remove the fill valve.
    Check the inside of the tank for smoothness and reassemble.
  4. jadnashua
    Leaks can be misleading as to where they are coming from...check the tank mounting bolts, too. The common mistake there is to install a metal washer inside the tank...doing that on top of the rubber gasket is an almost certain leak.
    While not common, the tank could have a hairline crack in it. Much more common on those shipped directly to you from an internet source than one you pick up from a local supplier, but not impossible. Toto's QA/QC is top line, but problems do occur - no manufactured product is 100%, and if it is, it's still subject to handling issues during delivery. Hopefully, all you need is to tighten things up.
  5. Mike_D
    Mike_D New Member
    May 21, 2012
    Thank you very much guys. I emailed Toto and they said to just tighten it until it stops leaking. I tightened it some more and it seems to be good for now but I will wait and see what happens in the next 48 hours.
    Thanks again,
    Mike D
  6. red92s
    red92s New Member
    Mar 9, 2011
    Atlanta, GA
    Do you use any drop-in chlorine tablets in the tank?
  7. Mike_D
    Mike_D New Member
    May 21, 2012
    Thank you for the suggestions guys. I simply tightened it and have not had leaks since. Will definitely keep an eye on it though.
    red92s, I do not use chlorine tablets.
  8. Terry
    Aug 17, 2004
    Well, that was a quick fix.
    I've never had the fill valve nut leak before on those tanks. It looks like the black mark on the fill valve nut and tank were a little offset. Normally from the factory they line up.
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
