Toto Drake/flange install question
Discussion in 'Toilet Forum discussions' started by jlsl1081, Jan 9, 2005.
  1. jlsl1081
    jlsl1081 New Member
    Jan 2, 2005
    Hummelstown, PA
    I'm planning on installing a Toto Drake, so I removed my old toilet today. The flange is securely installed to the sub-floor & there is ceramic tile on the floor now that extends 1/2" above the flange. However I plan on installing laminate tile flooring that is 5/16" thick on top of the ceramic flooring. So with the existing ceramic tile & the new padding & laminite tile, there will be about 1" from the top of the flange to the top of the new laminite tile.
    So what is my best solution concerning which wax ring to use? I've seen a 1/2" plastic flange extender at Home Depot that appears to attach to the top of the existing flange. Should I use one of these? Or aren't these a good idea? With or without one of these extender flanges, any suggestion on what type of wax ring(s) set up to use? On the toilet I took off it appeared they installed it using 2 wax rings put together.
    Also, do they make closet bolts long enough to reach my 1" distance from flange to top of floor, & then through the Toto?
    Thanks,
    John
  2. jadnashua
    First, I'm not a pro.
    The toilet flange is supposed to be on TOP of the finished floor. You've gotten away with it, but if there ever was a leak, the crud would now be going inbetween your flooring levels, and you might not know it until it had been happening for a long time.
    I'm not sure whether you can stack that many flange extenders together, but I'm pretty sure I've seen flange bolts long enough to work. Many of them come extra long with notches so you can break them off easily (well, moderately) to the proper length.
    I don't know how your flange is attached and what type of pipe you have or what access you might have. But, with this many layers, and the flange that far below the surface, you should consider raising the flange to the new floor height. Not sure what an inspector would say, it might not pass.
Similar Threads: Toto Drake/flange
Toilet Forum discussions Toto was grouted to my tile-cover grout with Loctite Polyseamseal or silicone? Friday at 6:16 PM
Toilet Forum discussions TOTO Nexus 1.28gal - odd throat opening? Thursday at 12:40 PM
Toilet Forum discussions Toto S350 e fan noise Mar 21, 2017
Toilet Forum discussions Toto Connect+ system - OK to buy parts (toilet+washlet) separately? Mar 17, 2017
Toilet Forum discussions Can this Toto set be purchased in the USA? Mar 15, 2017
